2004 Ford Ranger
Old Sep 7, 2014 | 11:11 PM
lstr81's Avatar
lstr81
2004 Ford Ranger
I am getting the code P2270 on a 2004 ranger 4.0 4 x 4. What icome up with was a misfire on cylinder 2. Can anyone help me with this. I have replaced MAF,and all 02 sensors. Coil pack, plugs and wires. All I have left is injectors.
Old Sep 8, 2014 | 09:59 PM
wtroger's Avatar
wtroger
Code says down stream o2 sensor bank 1 is stuck lean. Check for vacuum leak(s) if none show up check wiring to o2 or replace it.
Old Sep 8, 2014 | 10:40 PM
pawpaw's Avatar
pawpaw
Lets think about this some more. I believe P2270 is cyl bank 1, sensor-2 = the after cat converter O2 sensor on the passenger side, is lean, so since you don't have a lean code for O2 sensor 1, look for an exhaust leak upstream/in front of, the passenger side after cat converter O2 sensor.
Old Sep 9, 2014 | 12:04 PM
lstr81's Avatar
lstr81
Ok thanks
That is definitely the info I was looking for. I looked for vac. leak but didn't even think about exhaust. Much appreciated.
itswillist
Aug 5, 2017 02:04 PM
mfp4073
Mar 28, 2016 05:18 PM
logan1984
Nov 21, 2013 05:46 PM
neumayr83
Sep 10, 2012 06:33 AM
MCGA
Modular V8 (4.6L, 5.4L)
Apr 4, 2012 01:23 PM
