starter mesh problems
Old Sep 6, 2014 | 04:37 PM
bulethed's Avatar
bulethed
I have a 1993 f 350 with a 5 speed and a 460. when i got it a couple years ago the starter sounded bad, but it always started. i changed it out with a new gear reduction starter, it looked just like the old one. it sounds bad to, but i run it for about 6 mo. and it has now failed. looking at it its plain to see the drive gear is not meshing deep enough into the ring gear. it is engaging all the way inward, but just stripped the outside of the drive gear. i go get another starter and still have the same issue. i really need some help, thanks.
Old Sep 11, 2014 | 07:27 PM
bulethed's Avatar
bulethed
I still need some advice.
Old Sep 11, 2014 | 07:34 PM
eakermeld's Avatar
eakermeld
Inspect your flywheel real good. It may have a damaged spot on it that is killing your starter. Also, look at somebody elses flywheel teeth and compare that to yours. It may be severely worn or damaged and you don't realize it untill you compare it to a new one.
Kyle Wood
Jul 6, 2019 01:57 PM
grayson20
Sep 23, 2016 10:22 AM
1951flatheaddave
Mar 16, 2012 09:39 AM
78250crewcab4x4
Jan 22, 2010 10:28 AM
Dustin_86
May 1, 2004 09:18 AM
