Expedition issues/problems
Old Sep 6, 2014 | 08:15 AM
Dogmann's Avatar
Dogmann
I'm looking at used Expeditions. Everything from a 99 to a 2005. Were there any bad years that I should avoid?
Do the 5.4 spit plugs?
Old Sep 6, 2014 | 11:16 AM
r2millers's Avatar
r2millers
They've been known to if not torqued correct. Threads were just too short in the cylinder head and over tightening is as big an issue as under torquing. Always use anti seize when changing out.
Also, the 2005, 3valve heads, had split plugs which can break into pieces and create havoc to remove. Many threads on that issue here with remedies.
If 2005, just make sure the plugs were changed with the newer 1 piece type.
Gato Richy
Jul 27, 2014 10:09 AM
Mikec35
May 19, 2014 10:44 AM
mastiff
Oct 31, 2009 10:47 PM
krane operator
2004 - 2008 F150
Apr 13, 2008 09:17 PM
jeffrey101965
2004 - 2008 F150
Jan 4, 2007 05:41 PM
