Fuel Leak
Old Sep 5, 2014 | 04:18 PM
john.clark's Avatar
john.clark
Fuel Leak
I just put the IP back in and I have new leak that i cant figure out how to fix. Ok see if you can follow me on this as I cant upload picture. On the back of the injector pump are 8 fuel lines. 4 for the left bank and 4 for the right bank. They go back and curve down to connect to the top of the injector. Then they are held down by 5/16 inch nut or what ever you call it. When i tighten that down it leaks out of the bottom of that nut. Anyone have any idea how i can stop that from leaking? I have herd mention of 00 orings but i was under the impression that was for the seats of the fuel injectors.
Old Sep 5, 2014 | 04:33 PM
bashby's Avatar
bashby
Do you mean 5/8" nut? Where the injector line attaches to the injector? Injector lines are known to crack there. Id take it apart and inspect.
Old Sep 5, 2014 | 06:10 PM
tjc transport's Avatar
tjc transport
i ain't rite
what bashby said.
also, under the line is the return caps with o rings under the caps. when the caps are disturbed, the o rings like to start leaking
Old Sep 5, 2014 | 08:10 PM
john.clark's Avatar
john.clark
I had to replace the injector to solve the problem but I think it's the line that's bad. I just can't find the line at the moment.
Thanks again for the help again
Old Sep 6, 2014 | 06:46 AM
tjc transport
i ain't rite
there are only two place i know of that still sell hte lines, accurate diesel, and the diesel store.
they only list complete sets and they are EXPENSIVE.
but you may be able to buy single lines.
6.9L / 7.3L Injection Lines
DESETOF8 Set Of Injector Lines For 1983 - 1994 7.3L IDI & 6.9L Ford Diesel Trucks Only
DBGrif91
Feb 11, 2018 10:30 AM
GreenMtnMan
Oct 3, 2017 05:20 PM
Benny D
Nov 30, 2010 06:16 PM
Big_red78
Jul 21, 2007 10:24 AM
FMohlmann
Oct 10, 2006 08:57 AM
