6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Battery
Old Sep 5, 2014 | 10:45 AM
Tenvol1968's Avatar
Tenvol1968
Battery
Replaced batterys last year. On way home battery icon came in dash stays on. Any ideas, wanted to check here first before going any where 2010 F250 6.4 diesel
Old Sep 5, 2014 | 11:55 AM
senix's Avatar
senix
check your charging system. Sounds like the alternator. Load test the alternator.
Old Sep 5, 2014 | 01:32 PM
Tenvol1968's Avatar
Tenvol1968
when i pushed setup it said check charging system. how do i test the alternator?
Old Sep 5, 2014 | 02:00 PM
senix's Avatar
senix
You will have to go to someplace like Autozone and they can put a meter on it to see if it is charging.
It is free.
Old Sep 5, 2014 | 02:33 PM
Tenvol1968's Avatar
Tenvol1968
Thank you very much, made app with the shop that does my maintaince. Very nice fourm to get help that quick. THANKS
Old Sep 5, 2014 | 03:07 PM
RM2738's Avatar
RM2738
Have them check the batteries too. Had new batteries fail on me over the past year. One at 6 mos and the other 4 mos after that. So 10 months total.
Old Sep 5, 2014 | 04:02 PM
usedcartech's Avatar
usedcartech
On many of the ford charging systems I have checked I have found a 15 amp fuse in the main fuse block under the hood. It is marked "CHG SYS". If the fuse is still original it will be a blue 15 amp. Just check to see if it is hot on both sides of the fuse while in operation. If the fuse is good check all the wiring to the alternator. Just remember AUTOZONE can test your alternator off the vehicle if needed.
Ron C near Pleasant Plain Oh.
Old Sep 5, 2014 | 07:23 PM
Tenvol1968's Avatar
Tenvol1968
Thanks for all the information,
ROBBINthaHOOD
May 25, 2013 02:21 AM
Justin16
1997 - 2003 F150
Dec 20, 2012 10:50 PM
john1
Aug 22, 2006 12:46 PM
VIKING24
Feb 17, 2006 10:12 AM
speedofmouth
Mar 6, 2005 07:30 PM
