7.3l Delayed Start Issue
Old Sep 5, 2014 | 09:02 AM
BlackSmoke27's Avatar
BlackSmoke27
I just put a remaned 7.3l PS in my '96 F250. It was a long block and I used all the parts it didn't include from the old motor which ran great and started with little delay. (Changed the motor due to two large cracks in block) With the new motor, I have about a 10 second delay before it will start. Can anyone point me in the right direction on what might be causing this? I have already changed most sensors and the o rings on the IPR. Thanks for any and all help.
Old Sep 5, 2014 | 10:13 AM
farmert's Avatar
farmert
Delay as in cranking but not starting? How many miles since the install of the motor? You could still have some air in the system that hasent been worked out.
Old Sep 5, 2014 | 10:32 AM
BlackSmoke27
The truck cranks perfectly, just doesn't start as quickly as the old motor did. The motor has a total of about 15 miles on it. I was hoping the issue might be because of how new it is. Thank you for the reply.
Old Sep 5, 2014 | 08:17 PM
oldbird1965's Avatar
oldbird1965
I agree, it took me 160 miles to work the air out after an injector change once.
Old Sep 5, 2014 | 10:49 PM
fordpride's Avatar
fordpride
Run it some more. It has ail left in the system
Old Sep 6, 2014 | 11:05 AM
BlackSmoke27
Sounds good! I'll run it up to around 200 miles and post an update. Thank you all for the help!
boo-yaa138
Jan 20, 2009 04:00 PM
73FOMO
Jan 5, 2009 10:32 AM
xterrasdx
Nov 9, 2008 10:51 PM
jhemker15
Jun 27, 2005 10:08 AM
Ryan50hrl
Dec 6, 2001 07:18 AM
