radiator coolant
Old Sep 4, 2014 | 07:47 PM
lemasters f100's Avatar
lemasters f100
radiator coolant
Went to school and when I got there steam started rolling from under the hood. Radiator fluid all over the ground. The lower hose had barely any heat on it when I touched it. Also can't see any holes or rips in the hose itself? What could it be
Old Sep 4, 2014 | 07:48 PM
lemasters f100
1994 2.3 no a/c
Old Sep 5, 2014 | 06:43 AM
tmcalavy's Avatar
tmcalavy
Could be lots o' stuff. Get under the hood when it cools off. If you're lucky maybe just a bad hose...if not, thermostat, bad radiator, bad waterpump, bad heatercore, etc. are all possibilities.
Old Sep 5, 2014 | 08:11 AM
lemasters f100
I poured water into it when it was off and ir all came out at the timing chain area. Water pump?
Old Sep 5, 2014 | 08:17 PM
tmcalavy's Avatar
tmcalavy
More than likely...not a hard job, just messy and time consuming.
Old Sep 7, 2014 | 10:18 PM
Josh S's Avatar
Josh S
No timing chain on our 2.3's. Just a timing belt under that black plastic cover. The water pump is a good possibility but it could also be the thermostat cover which is right above the water pump. I actually decided to replace mine a few years back because it had just about rusted through. Maybe yours has.
joel79ford
Dec 26, 2011 08:59 AM
pebeme
17
Oct 4, 2010 03:16 PM
dbuck50
16
Jul 26, 2005 08:42 AM
Dustin_86
Jan 11, 2005 12:07 AM
rdltower
18
Nov 2, 2004 01:26 AM
