voltage regulator
Old Sep 4, 2014 | 04:52 PM
fmc400's Avatar
fmc400
MSEE
Based on your most recent description, I agree that it sounds like your truck is set up for idiot lights, and the PO hacked the wiring near the voltage regulator. My advice is to restore the wiring near the voltage regulator according to my first post, which is the correct configuration for idiot lights. This will set up the voltage regulator to match the idiot light setup dictated by your cluster.
Old Sep 4, 2014 | 05:11 PM
mikeo0o0o0's Avatar
mikeo0o0o0
To the OP, circle back to my post #13. Green Sales has 40 of the alternator harnesses for the idiot light instrument cluster.
This is the wiring harness from the alternator to the solenoid and voltage regulator.
Old Sep 4, 2014 | 05:13 PM
78fordguy's Avatar
78fordguy
Ok thanks fmc400 I will rewire it the way you said to using 16 gauge wire. The hot wire for the alternator you said should be a bigger gauge. Is 10 gauge good for that or should I go with 6 gauge? Ground for alternator I can use 10 gauge right? Should I also add a ground from a voltage regulator mounting bolt to the block ground? Should the alternator ground go to engine block ground or is the frame a good place for ground?
Old Sep 4, 2014 | 05:14 PM
78fordguy's Avatar
78fordguy
Ok I will check them out and see the price. If its to much money I do have tons of wiring from gauge 6 to 16 if you know the oem gauge for the alt harness.
Old Sep 4, 2014 | 05:32 PM
fmc400's Avatar
fmc400
MSEE
The alternator itself does not need a separate ground wire. It grounds by bolting directly to the engine block. You cannot achieve any better ground than that.
Technically, simply bolting the regulator to the inner fender should be a good enough ground for that. However, most alternators have a small case-mounted stud labeled GND. This can be connected to one of the regulator mounting bolts. This helps isolate load-dependent return current from the sense loop and gives a little better regulation. Many factory harnesses came with this. 16 AWG is more than enough for that.
If you have a stock setup without several aftermarket electrical loads, I think 10 AWG should be fine for the heavy alternator-to-solenoid lead assuming the battery and alternator are in the factory locations, not too far apart from one another. In that case, use a 14-AWG fusible link at the solenoid. Most parts stores sell these with the ring terminal already attached and molded.
Heavier gauge certainly doesn't hurt, but after 10 AWG you are too big for the standard type crimp terminals.
Old Sep 4, 2014 | 09:33 PM
78fordguy's Avatar
78fordguy
My alternatorn does have a ground stud with a ground wire from stud to innnerfender. I will add a ground from regulator to ground stud when I order the new harness. Thanks for the help!
Old Sep 4, 2014 | 11:02 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The stock alternator harness has a ground built into it that grounds the regulator to the alternator. On the stock set up, you can't see it because it's wrapped with tape, four wires go into the rubber strain relief but only three wires come out. The strain relief has a metal tab that is used to bolt it to the stud on the alternator case. This metal tab is the ground terminal.
Old Sep 5, 2014 | 01:14 PM
78fordguy's Avatar
78fordguy
Thanks mike I will go ahead and order the harness, by any chance do the rubber boots come with the harness? Mine are cracked and torn.
Thanks fmc I added a temporary ground 10gauge from regulator to the alternator ground until the new harness comes. I will update this thread when it arrives just incase the alt light doesnt work. Even though it should with new harness.
Old Sep 5, 2014 | 02:12 PM
fmc400's Avatar
fmc400
MSEE
I guess I'm confused. I thought you were building an alternator-to-regulator harness by hand, hence your questions. What is a harness being ordered for?
As I said in my previous post, 16 AWG is more than enough for the alternator-to-regulator ground. It carries hardly any current at all because the inner fender is already grounded. 10 AWG certainly works but it's a waste. The only 10-AWG wiring necessary here is the alternator output feed, coupled with a 14-AWG fusible link. If you've already got it set up, then leave it, I just don't understand the immediate deviation from my suggestion.
mikeo0o0o0's Avatar
mikeo0o0o0
Yup, they sure do.
This is the one I ordered. It's for a '73 so it's a little different than the one you'll get.
Old Sep 5, 2014 | 02:20 PM
fmc400's Avatar
fmc400
MSEE
Ah, got it now. Ignore my previous post. I missed the fact that Green Sales has so many in stock. Agreed, just get a ready-made harness. It will look nicer.
Old Sep 22, 2014 | 06:14 PM
78fordguy's Avatar
78fordguy
Yup, they sure do.
I got my wiring harness in today, it doesn`t look right. My alternator has a white connector on the alternator harness that connects to the F and STA on the back of the Alternator. The new harness has 2 seperate round connectors for the F and STA. I ordered D8TZ-14305-C the red sticker on the new harness reads D8TB-14305-CA. Did they send me the wrong harness or am I suppose to have the 70 amp alternator harness? The new harness also doesnt have the ground tab for the alternator like your picture shows.
I just noticed the local autozone has different Alternators some with alternator connector and some without. It would be faster for me to swap alternators as mine is under warranty. Would it be better to swap alternators to one without an alternator connector and use the new harness I just got? Everything seems like it would work then.
Old Sep 22, 2014 | 06:32 PM
  #28
mikeo0o0o0's Avatar
mikeo0o0o0
Look at the last picture in post #22, does the back of your alternator look like that one?
Old Sep 22, 2014 | 06:45 PM
  #29
78fordguy's Avatar
78fordguy
No my alternator does not look like the picture in post #22, mine has a connector. Local auto zone has an alternator that matches yours in post #22. Do I need to pick one up? Also what does the fusable link go to on the voltage regulator connector? My new harness doesnt even look like the picture in post #22 mine has 4 wires coming out, 2 wires go into a black boot. 1 orange wire goes into an orange boot and a black with red stripe bigger gauge wire goes into a red boot.
Old Sep 22, 2014 | 07:01 PM
  #30
mikeo0o0o0's Avatar
mikeo0o0o0
Does your alternator look like the one on the right?
