Big cert experience?
Old Sep 3, 2014 | 05:55 PM
78bigunns's Avatar
78bigunns
GEtting ready to work on my nephews 00' Ex.
Had a plug blowout, was repaired by Helicoil, but has blown again.
I've read many threads on Timecert, and using the Bigcert on a Helicoil'd hole.
Any first hand do's or don't for it? I feel like it should be no big deal for me, but would like any input one could give for it.
Also I was thinking now is the time to do spark plugs on the rig while I'm in there, stock Ford are the best is my understanding?
Many thanks!
Old Sep 3, 2014 | 06:42 PM
Restlesswildman's Avatar
Restlesswildman
I have had to repair threaded holes that have had helicoils in them. I always try to remove the old helicoil first. I have never removed on a head with a recessed plug before.
Can you remove the coil/spark plug tube?
Old Sep 4, 2014 | 11:40 AM
78bigunns's Avatar
78bigunns
All I have done is look at it. He bought it with a lift kit and huge tires on it, the hood is at my shoulder and I'm 6-4".
I was hoping to repair it for him without removing the head. I've never used helicoils. Is the best removal of them a left handed bit or extractor?
I just had to drill out a bunch of studs on a 460's exhaust for a project, I'm not really looking forward to this at all.
Old Sep 4, 2014 | 07:16 PM
Restlesswildman
I usually take a sharp pick and try to get either the start or the end of the Helicoil to pry/bend out of the threads. Then I take a pair of needle nose pliers and pull it out.
Old Nov 24, 2014 | 04:09 PM
78bigunns's Avatar
78bigunns
So my nephew finally picked up a timesert kit, and I'm attempting to do this for him. It all seems pretty straight forward.
I'm working on plug 4 and can't see in the hole. He said it was helicoiled but I can't see in it.
I was advised by timesert persons to start with reamer tool, and then proceed.
I've got this reamer tool in my air ratchet, grease on the flutes, going slow revs and making very little progress.
I can't get good direct pressure on it, and I think that is hampering progress.
Any thoughts? Everytime I run the ratchet I pull it clean off the very small amount of shavings the go again.
I feel like I should have bottomed out by now, and be cutting threads.
Thoughts or advise? Going to keep at it awhile.
Thanks
Blair
Pearlwhite94
Dec 7, 2008 07:47 AM
gradrgy
Jul 19, 2008 02:00 PM
g33uu
1997 - 2003 F150
Jun 6, 2006 04:25 PM
dassmoof
1978 - 1996 Big Bronco
Feb 16, 2003 09:54 PM
mgm415
Jul 7, 2002 02:17 PM
