95 f-250 how to go from dual tank to only single?
Old 09-03-2014, 12:06 PM
LutzBoy's Avatar
LutzBoy
LutzBoy is offline
so with this dual system setup, fuel can be transferred from one tank to the other. Well the back tank is leaking tried once to redo the lines, but that failed. so i just want to run off the front tank, i don't go on long hauls and i don't see me owning this truck for very long(would love to keep but the truck was not kept up and can't afford to keep replacing everything)
Old 09-03-2014, 12:11 PM
mrrish79's Avatar
mrrish79
mrrish79 is offline
Check out Bob G's 38 gallon tank install thread - might be an option if you only want one tank but keep the fuel capacity.
Old 09-06-2014, 06:23 PM
95F150SuperCab's Avatar
95F150SuperCab
95F150SuperCab is offline
I took the rear tank off mine to sand down the frame and the truck runs fine off the front tank. No gas leaking from disconnected rear lines.
Iantiler
17
02-08-2014 01:30 AM
Ryan0214
03-03-2013 06:13 PM
salewit
11-08-2007 02:02 PM
chrisvman
02-06-2005 10:15 PM
scott94f150
03-31-2001 07:33 PM
Quick Reply: 95 f-250 how to go from dual tank to only single?
