Sponsored by: Real Truck
rear brake line replacement
Old Sep 3, 2014 | 07:40 AM
powerstroker100's Avatar
powerstroker100
I'm going to replace mine before winter, I was checking things out and see that I have a line that runs from the abs valve to the frame near the drivers floorboard then is connected by a union running all the way to the rear hose.
When you guys replace this line are you running it straight from the abs valve to the rear hose or do you try to undo the line at that union near the drivers floor and connect there?
I'm most likely going to use premade 1/4" line and piece it together
Old Sep 9, 2014 | 08:32 PM
powerstroker100
Bump
10 chars
AKHunter93
Feb 24, 2017 06:06 PM
brimis
May 16, 2012 10:06 AM
BobbyB
Jul 11, 2011 10:35 PM
guillermorivera
Oct 22, 2004 04:27 PM
FRANKIE_FORD
Sep 20, 2004 10:57 AM
