Air Pump Removal… Pros? Cons? Tips?
Old 09-05-2014, 08:51 PM
Belleville Blue's Avatar
Belleville Blue
Belleville Blue is offline
When I did mine the crossover tube at the back of the heads was rusted off. I unbolted the plate for the tube from the back of the head, cut the tube off flush, then just turned the plate around to bolt the solid side to the head. Block off already made, nothing to build. Think I used a little high temp RTV to seal it.
Old 09-05-2014, 09:16 PM
dixie460's Avatar
dixie460
dixie460 is offline
Originally Posted by raystankewitz
Ya know, if it's not seized up, you will only gain less than 1/2 a horsepower.
doesn't seem to be worth the hassle to me.
That's just it though. Air pumps love to seize up and leave you stranded with a busted belt, so most of us ditch it and clear out that mess of plumbing at the same time.
Old 09-05-2014, 10:34 PM
fordboy97's Avatar
fordboy97
fordboy97 is offline
Great idea! Thanks. Now that's what I'm gonna do.
Pros- engine bay looks wayy better and much easier to work on it ,no more risk of the pump seizing up, less popping on deceleration, and the exhaust smell reminds me of an old carbed truck.
Cons- none!
Tanner
Old 09-16-2014, 08:57 PM
sparky23's Avatar
sparky23
sparky23 is offline
Does anyone know the new belt size for a 90 302 after pump removal? Gonna start cleaning mine up this weekend. Just got two new exhaust manifolds and gettin rid of the cats, figured might as well knock this out at the same time.
Thx
Old 09-16-2014, 09:06 PM
octaneforce's Avatar
octaneforce
octaneforce is offline
Looking to do this on my 4.9. Theres 6 holes in the head from this smog pump and they leak like crazy so its all getting wacked out.
ALSO if you remove the air pump to the cat YOU HAVE TO REMOVE THE CAT. The air pumped in allows the exhaust to burn hotter for emissions. Without this the cats will clog up pretty fast (granted they are still in good condition)
Old 09-16-2014, 10:12 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
You are almost right. The pump only puts air to the cat on startup. Once the engine warms up, the air diverter valve sends it to atmosphere. The cat will do its job just fine without it.
Thomscottson
02-13-2018 10:15 AM
95fiveoh
12-14-2017 06:42 PM
rangermann17
04-08-2009 10:06 PM
stm250
Exhaust Systems
05-05-2008 05:18 PM
eco
08-20-2006 08:05 AM
Quick Reply: Air Pump Removal… Pros? Cons? Tips?
