i dont know how to link to a craigslist ad but if you go to craigslist vancouver b.c. ... search cars & trucks for " 1968 Ford F100 Ranger "... a real cutie.
Is there a way to clean or polish the instrument cluster face to get it clearer? Mine is foggy and it can be hard to see sometimes. I see the one in this truck is beautifully clear and clean.
I have an extra lens I was going to try the headlight restore stuff on to see if it would clear it up. I have heard toothpaste works but never tried it.
I just did mine a couple weeks ago.
I wet sanded with 1200 grit. That's all I had and would go finer if you have it. Then I put a 6" buffing wheel in my hand held drill and buffed it out.
If I used my drill press, I found that I was using too much pressure and the plastic would just start to melt. I had a better feel with the drill.
The headlight stuff worked great! I can SEE my odometer now. Even from outside the truck. Before I could barely see it at all. I polished off all the gauges and it looks almost as good as new.
I'm familiar with the truck. I see it at the Cruise In. Great condition.
Change your location to Vancouver or wherever so that we know where you are for future reference. You can see we all have our locations on the right side of our posts.
