Are you familiar with the TPS (Throttle Position Sensor)?? There is a little servo motor on the throttle linkage, with 4 wires coming out of it. It moves a stop in & out to control idle speed, and the rate at which the engines revs drop after the throttle is closed. The SENSOR, which is on the throttle body, often becomes dirty, & fails to send the correct signals to the computer. Sometimes, if you clean the sensor real good, and check & clean all the electrical connections to & from the sensor and the servo, the problem goes away.
Hey Ken, I don't have first hand experience with the IAC, but I do have some TPS experience. I know that the TPS has a sensor on the throttle body shaft (on my CARB, it is on the passenger side, the servo is on the driver side). I don't know if FI engines have the sensor in the same location, or even if it looks the same. If I understand correctly, the IAC (Idle Air Control???) allows some fresh air to "leak" (or trickle) into the fuel/air stream to raise idle speed without actually moving the linkage, whereas my TPS actually does move the linkage. Am I on the right track with that??? If yes, did they stop using TPS altogether when they instituted IAC??? Or do some engines have both??? I also don't know what year they started installing IAC.
rjschlif, if I completely confused you, so sorry. I should do a little homework on IAC (and TPS maybe also).
FI engines have a TPS that only tells the PCM what the position of the TP is, the IAC controls the idle speed. Didn't realise you had a carbed enigine, I guess the TPS is different on them, I'm not familar with that setup.
HI all thanks so much for your help. I found what I thought was the TPS (four wires attached to a plug, which is attached to the throttle body. I removed the screw holding it to the throttle body. Nothing mechanical must be a sensor. (The pins are slightly corroded hard to clean) It was attached to the back of the throttle body near the firewall.
Any idea of what I found?
Thanks, Rick
Originally posted by rjschlif HI all thanks so much for your help. I found what I thought was the TPS (four wires attached to a plug, which is attached to the throttle body. I removed the screw holding it to the throttle body. Nothing mechanical must be a sensor. (The pins are slightly corroded hard to clean) It was attached to the back of the throttle body near the firewall.
Thanks, Rick
The IAC has two wires and the TPS has three wires which is usually directly opposite of your throttle linkage on the body. Some TPSs had/have a WOT switch but I thought that wasn't on Fords might have four wires.
Was there a shaft inside the hole with flats on it and the unit you remove spring loaded, it is the TPS.
