high boy bed
Old Aug 30, 2014 | 02:36 PM
lafermedavid's Avatar
lafermedavid
high boy bed
I have a chance to get a high boy bed for my hb chassie.Im going with rear gas tank,,,the fellow mentioned round rear imprint for gas fill.I know hb had in cab tanks,what would i need for rear fill on this high boy bed? standard filler neck?
Old Aug 30, 2014 | 04:05 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
What kind or rear gas tank, cause a standard width frame one will not fit, so I hear...but a 23 gallon little 90's ish Ranger truck plastic one will fit, so I hear anyway.
Cut a gas flap recessed hinge area out of a junk bed and weld it in. Might have to shorten the filler neck just a bit?
How it that for a guess?
Old Aug 30, 2014 | 04:32 PM
lafermedavid
hb
the hb bed has this plug,where they used the bed for (Iguess )2 wheel drive vehicles....I will need to remove plug,and go with filler neck,,,,trying to hit reveiws up see if any one has done that on there hb
Old Aug 30, 2014 | 04:49 PM
77&79F250's Avatar
77&79F250
Oh so that bed has that style like a old 73 exposed gas cap, but its plugged like a CC F250 2wd short bed (they plugged the front tank spot) got it now.
Can you locate a JY bed with a exposed filler neck cap and get that filler neck?
I can make a JY lap in a month as soon as I am off the road. I have seen that style of bed and filler cap up there.
Old Aug 30, 2014 | 05:08 PM
lafermedavid
rear filler
thanks Rich I really appreciate the offer,just trying to find if its out there for sale.I was researching and saw Hickory bed had the oval filler in the rear....if I cant find it Ill take you up on the offer if its still there.Thanks for your help......looks like Marks bed,but with the filler plug and its long
Old Aug 31, 2014 | 10:49 AM
czaroc's Avatar
czaroc
My 74 Crew short bed has a plugged rear tank hole. Have an in-cab and midship tank. It's half rust though; the cap traps water.
Old Aug 31, 2014 | 11:36 AM
lafermedavid
bed plug
thanks czarac,yes thought they would trap moisture just like moldings,this thing will be under shelter
pipeliner83
15
Mar 26, 2014 06:12 PM
Andrew7dg
Nov 29, 2011 10:44 AM
Myfreeford
Mar 12, 2011 09:57 AM
Fattydaddy100
Apr 25, 2006 06:12 PM
taketheredpill
Aug 24, 2003 11:13 AM
