Lift Pump Installation
Old Aug 30, 2014 | 10:22 AM
dieselsndoggies's Avatar
dieselsndoggies
I have been struggling with the truck (83 F350 6.9 IDI) dying on and off for a month. I have changed lines, the fuel filter, tightened up everything although I do need an o-ring on one of the injectors, but that didn't prevent it from running well for 2000 miles and is just barely damp not wet. It hasn't been getting fuel and now it appears it's not getting any -my friend whose good with diesel tractors told me it's the pump.
I am now going to install a new lift pump. I am worried about the cam position being right. Can anyone advise?
Thank you in advance.
Joe
Old Aug 30, 2014 | 01:41 PM
Orpackrat's Avatar
Orpackrat
Just to verify, have you disconnected the line on the fuel filter coming from the pump and cranked the engine to see if fuel is coming out?
If fuel is not coming out, its probably the lift pump, if there is fuel, it could be the injection pump...
With the 3 lift pumps I have changed, I have not run into the issue of the wrong position... Each installation was just fine. I do recommend removing the vac pump and such though, otherwise its much harder to install.
Old Aug 30, 2014 | 02:07 PM
dieselsndoggies
Lift pump installation
No I have not,but I will verify as you have suggested. If this is the case then what could it be ?
Old Aug 30, 2014 | 02:23 PM
Orpackrat's Avatar
Orpackrat
if the fuel pump is working, next would be to reconnect the fuel line to the filter, use a 5/8" wrench, loosen the inection lines on top the injectors and crank the engine with accelerator down...
If no fuel comes from the cracked lines, you need a rebuilt injection pump. They are not to hard to install much easier on a truck than a van but still fairly easy.
Old Aug 30, 2014 | 03:11 PM
dieselsndoggies
Ouch!
I will do as you say-I hope not because I just replaced the injection pump with a new Stanadyne one two years ago but with my luck you never know. Since my truck is stranded 30 miles away and I can't get there today I will be gone from the forum until I have tried these things.Again thank you. Joe
Old Aug 30, 2014 | 03:26 PM
Chevy_Eater's Avatar
Chevy_Eater
OR he's not getting power to the FSS.
Old Aug 30, 2014 | 03:33 PM
Orpackrat's Avatar
Orpackrat
Easy test, with ignition on, disconnect the wire in the IP and reconnect and try to hear it click in operation.
Sulley8055
Jun 2, 2016 05:27 PM
Fixnstuff
Apr 5, 2016 07:54 PM
troutski
Oct 19, 2014 10:24 PM
Nick bass
Aug 12, 2012 09:30 AM
texasjack
Dec 9, 2008 09:24 PM
