Regen Observations
Old Sep 14, 2014 | 07:42 PM
Dascro58's Avatar
Dascro58
Another entry on my observations of regen on my 2015. This one was during towing our camper home from the Hershey RV show today.
When we left the campground the soot level was 2.41. It increased to 2.54 during the first 20 miles or so and then began reducing via passive regen until the soot level reached 1.54, then it went into active regen. That lasted about 24 miles and reduced the soot levels to 0.74. The soot level did not continue to drop any further after the active regen stopped but I was pulling a grade when it stopped.
So this active regen was somewhat different than the one I observed before while not towing. This time active regen started while passive regen was dropping the soot level. It was 424 miles since the last active regen.
Old Sep 15, 2014 | 06:09 AM
Lastwagen's Avatar
Lastwagen
There are definitely some changes with the regen process on the 2015's. My 2012 would always start at 2.67 and never varied. Either something other than soot level alone or a combination of things like DPF soot mass or DPF pressure initiates the process. Regardless, more miles between regens is what we want.
Old Sep 15, 2014 | 05:29 PM
gsxr1300's Avatar
gsxr1300
When towing my 2011 will regen every 500 miles or so even if the soot it low. Once it started at 1.3 and it dropped to .67.
Old Sep 15, 2014 | 06:59 PM
Dascro58's Avatar
Dascro58
I'm posting these regen observations from my 2015 to share what I'm seeing versus what others may have seen on the 2011-2014's. At this point I'm inclined to believe there may be a different regen strategy based on what I've read historically versus what I'm seeing. Too early to tell for sure though.
But I've seen empty, non-towing soot levels into the 3's before active regen is initiated. Now I've seen effective passive regen overridden at relatively low soot levels. Overall, towing to non-towing I'm seeing active regen's around 400-500 miles regardless of soot levels.
Old Sep 15, 2014 | 07:30 PM
720Deere's Avatar
720Deere
Regen habits change with increased miles. A new truck regens differently than one with 80,000 miles on it.
Old Sep 15, 2014 | 09:20 PM
FishOnOne's Avatar
FishOnOne
What habits change about the regen with a truck with 80k miles? What's different? The frequency? If so, does it get better or worse?
cookingguy
Mar 24, 2018 10:00 PM
jakgod3
6.4L Power Stroke Diesel
Apr 26, 2016 08:45 AM
Rick Cargo
6.7L Power Stroke Diesel
Nov 1, 2012 07:50 AM
2001400ex
Sep 4, 2009 03:11 PM
Silver Streak
May 24, 2006 06:39 PM
