Steering Problems
Old Aug 28, 2014 | 08:36 PM
Whatmough's Avatar
Whatmough
Steering Problems
I have a steering issue that comes and goes.
It started after I was driving down a dirt road and hit a pothole pretty hard... I heard what sounding like metal snapping near the left front tire.
Now when I am driving, usually after a sharp corner the steering will have a mind of its own, it feels like the tire is wobbling or something like that making the truck want to do little swerves left and right.
Old Aug 28, 2014 | 09:21 PM
ddetrick78's Avatar
ddetrick78
I had that problem when i bought my truck. I replaced the steering damper and it seemed to fix it for a little while, but eventually returned. I ended up having to replace the sway bar bushings, and both of the linkages. That corrected the problem completely for me. Also make sure your tires are fully inflated, as lower tire pressures seemed to make it a lot worse for me.
Dwayne
Old Aug 28, 2014 | 09:24 PM
mhoefer's Avatar
mhoefer
Ball joints? Linkages, steering damper? There is a lot of things to check. Alignment can give you problems too, read up on death wobble, you may have just blown the alignment.
Old Aug 28, 2014 | 10:34 PM
9228.bobcat's Avatar
9228.bobcat
Yea might want to check ball joints.
Old Aug 29, 2014 | 07:54 AM
samsdad02's Avatar
samsdad02
friend of mine did that, was one of the steel belts in the tire.
Philisophe
Oct 30, 2018 10:59 PM
svastano
Oct 15, 2017 09:15 PM
smashclash
Sep 14, 2010 08:23 AM
Team Violence
Dec 26, 2009 10:38 AM
hammer65
Feb 27, 2009 05:18 PM
