vin: number location?
Old Aug 28, 2014 | 07:06 PM
lonewolf5348's Avatar
lonewolf5348
I have a 1955 street rod I finished in 1999 I am thinking is selling it but I can't seem to remember were I place the original tag that was inside the glove box. I have a boxed front end so I would say not on the driver side rail any longer .I wonder any were else to look
Old Aug 29, 2014 | 04:28 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
[QUOTE=lonewolf5348;14621875]I have a 1955 street rod I finished in 1999 I am thinking is selling it but I can't seem to remember were I place the original tag that was inside the glove box. I have a boxed front end so I would say not on the driver side rail any longer .I wonder any were else to look
VINs are on the passenger side not the drivers side. 53-55 are on the top of the frame close to the radiator cross member. If you have a title you can have a new plate made.
Chassis and VIN Plate Stamping | Data Plate Embossing | Metal Tag Stamping
Old Aug 29, 2014 | 04:48 PM
harleymsn's Avatar
harleymsn
[QUOTE=bjmayberry2;14624353]
I don't think any of those European tags would be considered acceptable by any US authorities. Besides, the frames did not have tags, the frames were stamped.
My best advise would be to contact http://www.datatags.com/
Old Aug 29, 2014 | 04:58 PM
bjmayberry2
Sorry thought I sent you this dataplt@bresnan.net "I just need rubbings or pix of old tags with the codes wanted written off to the side to be sure.
The price is $100 per tag.
Send a check to BRETT STOUTENBERG
P.O.Box 40011 Grand Junction, CO 81504" Tags Backeast, Trim Tags Backeast, Data Plates, A.G.Backeast. We make tags for AMC, Buick, Cadillac, Camaro, Chevelle, Chevrolet, Chrysler, Corvette, Dodge, DeSoto, Edsel, Ford, Frazer, La Salle, Henry J, Kaiser, Lincoln, Mercury, Mustang, Oldsmobile
Old Aug 29, 2014 | 09:36 PM
Okiedokie's Avatar
Okiedokie
My 53 is stamped on top of the front crossmember on the passenger side. Just below and behind the radiator.
Old Aug 29, 2014 | 11:01 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Sounds the same as mine. It's located in the red box below.
If you don't care if the ID plate is embossed or engraved, any trophy shop can reproduce it. You just need a good, clean picture for them to work from.
Old Sep 5, 2014 | 05:32 PM
lonewolf5348
can I locate it without removing the radiator
Old Sep 5, 2014 | 05:52 PM
EffieTrucker
Yes. It is behind the radiator, not under it.
You will probably have to clean the frame to find it, but be careful. The numbers may not be stamped very deep and if you use a power sander you could sand them away. Do not use a grinder to clean it.
Old Sep 5, 2014 | 06:50 PM
gerrymoe's Avatar
gerrymoe
Miy 55 panel # is on top of frame just in front of the front cab mount passenger side, so was my 56. You can see it (if it is clean) with a mirror inside the wheel well. If not you have to remove the inner fender panel.
Old Sep 5, 2014 | 07:05 PM
lonewolf5348
thank you I try tomorrow
Old Sep 7, 2014 | 12:52 PM
lonewolf5348
well no luck I used a stripper chemical to clean the paint off no luck no serial numbers any other location that some one knows off?
Old Sep 7, 2014 | 03:51 PM
bjmayberry2
I'd still contact BRETT STOUTENBERG. Maybe he can make you a plate from your title. You probably ground and welded the Frame VIN off while boxing it. Otherwise you'll have to have it inspected and will probably end up with a state assigned VIN.
Old Sep 7, 2014 | 04:27 PM
lonewolf5348
I think they may be the only way to get it re-vin
I did have the PA. tile when I purchased it back in 1997 but in N.Y.S. you must surrender the title and they give you a transferable registration if the veh: is older then 1973
I have the original vin number on the registration but no were to verifier it on the the truck.
Old Sep 7, 2014 | 04:42 PM
bjmayberry2
Could be a sticky issue. Not sure if NY will take the plate in the glovebox as the VIN or not but you need to get it fixed or you'll never be able to sell it.
Old Sep 8, 2014 | 06:15 PM
lonewolf5348
I do have another option have the truck transported to my second home in calabash n.c.
I did speak with a DVV inspector last year before I left he stated as long as the truck is registered and insured they will have me post a bond and they will re-vin it or line in N.C. issue me a new title. I was also told to have a early registration if I can to show them I do own the truck back when I finished. I did some searching and found a 1999 reg and now I just did re-reg and have a valid registration good to 2015 .
any one have any dealing with DMV inspectors in N. C.
