wiring issue?
Old Aug 27, 2014 | 09:31 PM
1990-f250's Avatar
1990-f250
wiring issue?
Hey guys, today when I got done mowing I went to start my truck and all I got was a click , and all my power shut off. After the power would shut off it would come back on really dimly until you hit the starter solenoid on the fender then the cab light would come on bright. The truck would turn over if you shorted the positive to the ignition point, but will not if you short it to the other lead. We tried changing out positive cables now I have no power at all anywhere, we still measure 12v at the solenoid. Any ideas at all this is driving me crazy
Old Aug 28, 2014 | 09:32 PM
1990-f250's Avatar
1990-f250
Any recommendations guys I really want this thing back on the road
Old Aug 28, 2014 | 09:35 PM
carguy94's Avatar
carguy94
check for power when you crank it. I assume by no power any where it wont even click and no fuel pump no dash lights or anything. how did all the connections look. how fast does it crank
and what engine is in your truck any recent repairs or problems
Old Aug 28, 2014 | 09:47 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Corroded connections.
Take apart the connections at the solenoid, clean them with emery paper or anything else scratchy. Clean the battery posts, positive and negative. Put it back together and congratulate yourself on a job well done.
Old Aug 29, 2014 | 07:26 AM
f150dan93's Avatar
f150dan93
radio
I just got an 87 f150 but someone stole the radio and clipped the plugs to it while the previous owner had it does anyone know the color codes I tried and got and failed many times
Old Aug 29, 2014 | 08:31 AM
rla2005's Avatar
rla2005
Welcome to FTE!
It is considered rude to tag along on a thread for an unrelated issue. Please start your own thread.
You might try this too: http://bit.ly/1osrTtr
Sorry if I come across as crass....we are friendly folks here.
Old Aug 29, 2014 | 12:37 PM
1990-f250's Avatar
1990-f250
Just put the 302 in it a couple months ago. When you jump the positive solenoid to the ignition nipple it cranks very hard . I will try cleaning the connections at the solenoid but the battery ones are good I believe. I was thinking it might be the fusible links?
fosheezy 250
Nov 17, 2018 08:46 PM
Curtis Gruman
13
Oct 18, 2015 10:53 PM
strokin'_tatsch
Jun 27, 2015 02:23 PM
egrubb460
Nov 23, 2013 12:07 PM
bigd312011
16
Mar 2, 2012 05:48 PM
