Sponsored by: Real Truck
Driver headlight keeps blowing
Old Aug 27, 2014 | 06:46 PM
3/4ton4X4's Avatar
3/4ton4X4
Got a little wild while i was in the trails the other day and was bouncing pretty hard and my headlight blew. Well now im on my third one and id suspect a short. This time it blew the bulb right apart so it must have got pretty hot. Any common problem areas i should look into before trying to figure this out?
Old Aug 27, 2014 | 07:04 PM
JWC 3's Avatar
JWC 3
Is there moisture in there? That will pop a bulb .
Old Aug 27, 2014 | 07:23 PM
3/4ton4X4's Avatar
3/4ton4X4
Im not sure but that's a good place to start, the first time it did it the ring style clip popped off and the headlight came out and was dangling but the last 2 have just blowing and stayed inside. But now that you say that maybe when the first one came out it let some water in. Thanks!
Turbostixxx
Feb 5, 2015 06:14 AM
SteelHorse08
2004 - 2008 F150
May 21, 2008 03:44 PM
HUNTER10
Jan 30, 2007 09:26 PM
BroncoBoss351
1978 - 1996 Big Bronco
Sep 29, 2006 06:01 PM
Stagecraft Chris
Sep 14, 2003 03:08 PM
