.. then start troubleshooting the wires to determine what signal is present during certain settings. If there is voltage present when there is supposed to be none, then the problem lies upstream of that component. Also verify that the wires and terminals were not switched or spliced incorrectly.
Basic troubleshooting through deductive reasoning.
One learn how to use your test meter.
Then place on DC voltage Place the red lead on the +side of Battery & other to any ground the meter shows Voltage Right! Do the same with each hot wire going to the light. Remove The light plug and test each wire all while using the high & low beam switch.. You floor high & low beam switch may be bad..
Orich
