power assist steering?
Old Jul 13, 2003 | 09:10 AM
57_ford's Avatar
57_ford
Hi I have a 73 F150 4wheel drive with power assist steering. I scearched the past posts. I can not find any that have gotten it to work. I like to try to keep things like Henry built it well for the most part. The problem is it has very little assist. I replaced the pump and their are no leeks in the system. Seems like every one has the same problem. I can not believe that ford can sell these trucks when they were new driving like this. So has any one been able to get this set up to work? I have read in past posts that the steering pumps were different. What should the working pressure be? If all else fails I have all the parts to convert it but I want to give it a shot.
Old Jul 19, 2003 | 12:55 PM
sfccope's Avatar
sfccope
Hey guy sorry I can't help you on that but do you know what it takes to convert an f100(1974 4x4) to something that actually works?
sfccope
Old Jul 20, 2003 | 08:07 AM
57_ford's Avatar
57_ford
Thanks for the reply, I have read several diferent ways of converting it to power steering. I have a 79 power steering box and I am good with a welder. I think I might use the pipe throu the frame method. I thought if I just fix what is their it would be easier. Is their a better way?
