Original 1950 Tail Lights
Old Aug 28, 2014 | 08:09 PM
  #31
Skalywag's Avatar
Skalywag
I just bought a pair of original style tail lights from Midwest Early Ford but I opted for the stainless steel version, not dark side, just slightly toasted. They were $30 each. I really like them.
Old Aug 28, 2014 | 08:22 PM
  #32
abe's Avatar
abe
Originally Posted by ALBUQ F-1
You could, if you bought the correct type of SignalStat. Some SignalStats used dedicated turn lights, others you cut into the brake light circuit to use the existing dual-filament bulb.
Yes, I used the Signal-Stat turnsignal unit that my grandfather put on who knows when to comply with PA State Inspection laws.
Old Aug 28, 2014 | 08:43 PM
  #33
FortyNiner's Avatar
FortyNiner
The older versions didn't lend themselves to single signal /light schemes. My signals were also separated from the lights - an upgraded Signal-Stat did the trick.
Old Aug 28, 2014 | 09:13 PM
  #34
WingingIt74's Avatar
WingingIt74
Old Aug 28, 2014 | 09:15 PM
  #35
WingingIt74
Old Aug 28, 2014 | 09:48 PM
  #36
ben73058's Avatar
ben73058
Hey Travis,
Nice '50 over there! It's pretty straight forward to get those little parking lights in your front grill to be your front turn signals. We had some very dim trailer lights on the back. I wasn't comfortable driving around Austin with 50,000 students & 100,000 Hipsters with dim tail lights. We over corrected for that....
Ben in Austin
1950 F1
Old Aug 29, 2014 | 07:00 AM
  #37
38 coupe's Avatar
38 coupe
Someone covered over the mounting holes. You get to re-drill those holes if you want original looking lights and mounting brackets.
Old Aug 29, 2014 | 03:00 PM
  #38
Wayne Waldrep's Avatar
Wayne Waldrep
this is a poor picture and the wrong light but you can see the idea.
Old Aug 30, 2014 | 01:02 PM
  #39
D Sokol's Avatar
D Sokol
A note about tail lights and license plates....
If the tail light bracket is mounted "stock", a stock mounted rear bumper will block the plate. Here in Arizona, that is legal as long as the vehicle is "restored to as assembled condition".
Check your local laws, but if your state does not allow that than you have to invert the mounting bracket which will raise the height enough to make your plate visible.
DjS
HILLBILLY BOB
Feb 27, 2019 12:16 PM
flavo
All Other Items for Sale
Jun 30, 2013 06:51 PM
Hdslider
6.7L Power Stroke Diesel
21
Feb 10, 2013 02:07 PM
1994F2507.3L
34
Dec 22, 2010 07:31 PM
