NO START....Did I speak toooooo sooon?
Here is where I am at.....yes, it was def. a plumbing issue that I made when I put the tank back in after repaint.....I hooked the return line up to the supply line and the supply line up to the return inlet......introducing nothing but air once the WVO went dry.....
I have since changed the lines around, replaced the fuel filter, purged the system and have some firing but the truck won't start.
It feels as if it is only firing on one side if that is possible.
Gonna try a few other things, but I am open to suggestions. My brother, who has the same truck said it may be the CPS....I am open to trying one of those.....But still, open to suggestions.
Thanks Andys350......that was a helpful couple of posts....
But I think the truck would start after the ICP being unplugged, the default should put it at 2000psi.....
This really sucks. I basically just ran the thing out of fuel last night, this shouldn't be this difficult......
I thought maybe because it was shut down on veg oil, maybe it got a little "thick" today....so I now have the batteries charging and the block heater on to warm it up a little....We shall see....if not, I leave for vacation tomorrow and will be driving a darn Chevy gasser.......to the tune of about $300 bucks in fuel.....I am used to it being free with veg pulling my pontoon......oh well....I'll make more.
Disconnecting the ICP sensor doesn't set the pressure to any certain level, per se. What happens is the PCM reports the value it *thinks* the ICP should be based on other parameters, and under the assumption everything else is functioning normally.
What are you using for a scan tool? Can you monitor live data with it while cranking?
It was a snap on, the guy said it cost about 15,000 and another 1000 a year to update...either way, it wasnt all what it was cracked up to be. First, he couldn't bring up any data, then he got in.....I asked him about buzz testing everything and reading while we cranked......
Well, he got some data, told me it was "stored data"so who knows when the codes were pulled. He then said sometimes when the codes are wiped, the vehicle will start...as soon as he reset the codes, the scanner kicked him out and he couldn't get back in....so long story short, it was a bust. But I do appreciate him trying.
I finally got the truck started...I think the block heater did the trick. It ran really rough, could only get about 30mph out of it. The banks six gun was reading and ERROR ICP. I started it with the sensor unplugged. the service engine soon light was on too. I plugged the ICP back in, no difference, idled and drove really rough. I shut it off and started it up, ICP warning went away, the dash light was off....but it still ran rough...it idled down and finally shut itself off. I couldn't get it back running again...mainly because I am burnt out.
Vacation time, so I will get back at it when I get home. I am confident it will run again. Next time I get it started, I am going to make sure I have an appointment somewhere that the equipment works.
Thanks for your patience...i appreciate your advice, recommendations and comments. I will be back on this when I return, so there will be more to follow up on.
Mike IN MN
Mike IN MN
I was going to start at the tank....I had my dad turn the key to the on position while I was under the diesel tank....no buzzing, no humming no vibration on any of the lines. I also had him do it while I had my ear at the fuel door.....no noise coming from there.....someone correct me if I'm wrong, but shouldn't that be making some noise st the cycle of the key?
#29
Ok, so after a weekend of fishing and pondering, I came to the conclusion it was def. a fuel delivery issue, pretty easy to figure that one out. and it was before the HPOP with what I had diagnosed earlier.
I finally ran across the "GUZZLE" page and realized the fuel bowl/fuel canister needs to hold some fuel pressure and there is a pressure relief valve on the drivers side top of the fuel bowl, or return line to the tank.
Here I found the issue. The housing on the relief valve was broken, I located the spring inside the fuel line before the first bend....no valve, no pressure...
I will update on when the parts come, but I am certain this is the issue now, with broken parts in hand.. pretty simple fix, as most things have been.
motomax55
02-21-2015 11:35 AM
tr0y
03-17-2013 05:51 PM
butler1975
08-24-2012 11:44 AM
