Hi everyone, besides my introduction last week - this is my first post. I know how to find information here on the site regarding HPOP and other oil related posts. However, I have a special question. Here's the scenario with known facts:
Stock oil pressure indicator has always read normal. No strange surges.
Installed AutoMeter digital cobalt series last December, and idle pressure was always 20-30 psi
Today it dropped in the single digits and even hit ZERO! But the stock gauge was still remaining faithful. So, I put the truck in neutral to idle up and move oil around until the light turned green.
I got home, and found the aftermarket sending unit to be loose. I tightened it up, and pressure went back to double digits, but was sporadic at best. Well on my test drive - it started dropping into the single digits and even zero again.
Has anyone here had this happen? Would there be a chance my new gauge is out of wack?
The gauge on the dash has two positions, Normal and Nothing. The sender is a switch, not a sensor, so that's all it does. Can you put a mechanical gauge on it to see if it does the same thing? If it's steady with a mechanical gauge, the sending unit for your aftermarket gauge is probably faulty.
Oh, and I assume you did check the oil level, right?
You could either tee a gauge in there, or use a #4 ORB adapter in the plug on the top of the HPOP reservoir. The pressure may be a little different at the reservoir, but if it's rising and falling, it should do it at both ports.
It's "o-ring boss." Most hydraulics shops should have them. Commonly, pressure gauges have 1/8" NPT pipe threads, so you need an adapter to thread in to the top of the reservoir.
