fuel pressure
Old Aug 26, 2014 | 06:04 PM
njtinman2's Avatar
njtinman2
fuel pressure
i have a 1994 f150 supercab 4x4 5.0 and need to know what the fuel pressure should be i only have 30 psi running
Old Aug 26, 2014 | 06:22 PM
Evan_P's Avatar
Evan_P
If that's with the vacuum line on the regulator, that is about where it should be.
Old Aug 26, 2014 | 07:16 PM
Conanski's Avatar
Conanski
Gauge readings can vary a little so if you're in the ballpark here you're probably fine.
At idle you should see 32-35psi with vacuum attached to the regulator as it should normally be, and 39.5-45psi with vacuum removed from the regulator. Here's the key thing, pressure should ALWAYS increase towards the higher levels when the throttle is snapped opened quickly or the engine is placed under sustained load while the vehicle is moving. Dropping pressure is weak pumps, clogged filter, or leaky injectors, but if your gauge produces 30 and 38psi with these tests then you're probably fine, it looks a little low but that could be gauge calibration error.
Old Aug 26, 2014 | 08:00 PM
njtinman2's Avatar
njtinman2
filter is new. i did a tune up not that long ago or should i say miles ago but its running not to good lately and when the humidity goes up it runs worse. maybe i have to change the cap and rotor again. it has a slight miss under a load and now it is getting worse
edo488
Jul 4, 2016 10:25 PM
capriceragtop
Oct 1, 2013 02:39 PM
Craigwell
15
Jun 13, 2013 06:44 PM
special blue
1978 - 1996 Big Bronco
Dec 24, 2012 10:49 AM
Shawn3778
Oct 1, 2003 10:15 AM
