2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
no cold air from ac
Old Aug 24, 2014 | 09:21 PM
jle70's Avatar
jle70
no cold air from ac
I have no cold air from the air conditioning. Front or rear. The compressor runs and condenser sweats, so I know it is running. So, my conclusion is the blend actuator. Thoughts?
Old Aug 24, 2014 | 09:39 PM
alwaysfords41's Avatar
alwaysfords41
If it is a front only problem, it is a blend door axle. If it is a rear only problem it is a blend door actuator. To lose cooling in both it is something else.
Old Aug 24, 2014 | 09:42 PM
jle70's Avatar
jle70
I have read to spray cold water on condensor, see if it works then. I just have no clue when it comes to AC.
Old Sep 5, 2014 | 06:20 AM
jle70's Avatar
jle70
Update- mode door was not fully seated to ac. Mode door actuator gears were out of sync. I fixed both, still only got ac to 64°. So, bought hose with gauge, added one can freon with dye, 2 cans regular. Ac is cooling, not perfect yet. Now to search for leak. I hope it is something cheap and easy......lol
CharlieBravo
1997 - 2003 F150
Apr 26, 2010 10:20 PM
Arknessee
2004 - 2008 F150
Apr 8, 2010 06:34 AM
ducky
Jun 11, 2008 07:39 PM
Russ79
Jun 14, 2005 12:12 PM
Ritchdude
Mar 3, 2004 12:28 AM
