AC blows hot air.
Old Jun 11, 2005 | 09:33 PM
Russ79's Avatar
Russ79
AC blows hot air.
I have a 1999 Expy EB with a 4.6 and 60000miles. When I turn on the Automatic temperature control it usually blows hot air for long periods of time. It rarely is consistent in blowing cold air, until I engage the rear ac. When I turn on the rear ac then the front vents will begin to blow cold air. According to R134 pressure gauge that came with my recharge kit my pressure is fine and where it needs to be. I haven't noticed the AC compressor to not run. This occurs even when I run MAX AC. Any ideas?
Old Jun 14, 2005 | 12:12 PM
skysurfer2010's Avatar
skysurfer2010
sounds like a lot of the same problems i'm having. the conclusion i'm coming to isa that it's most likely the blend door! $$$$$$$
