Engine Stall declaration
Old Aug 23, 2014 | 05:31 PM
Krinderhagen's Avatar
Krinderhagen
1988 F250 Lariat Diesel
Engine stalls after releasing throttle pedal i was considering the temperature though after running for 40 minutes at idle in park not would not reach 192 degrees, there was word that pistons burn so i think a cylinder test would be appropriate
Anyone with heads up on the situation
The gauge on the dash is almost half using a Cen tech infrared thermometer
The temperature at the thermostat housing and neck read between 178 and 183
08/22/2014 F250 Lariat thermo temp
1988 F250 Temp gauge reading
when accelerating at 2000 RPM for few the releasing the throttle the engine quits same scenario when driving and preparing to stop the engine will quit
Video
after letting it idle for 15 minutes it still has not reached temperature above 190 so have ot been able to check if thermostat opens
A new thermostat calls for Part Number: 4399
Weight: 0.2 lbs
Warranty: 1 YR
Application: OE recommended temperature
Notes: 195 degreesSeal included
Gaskets Included: Yes
Material: Stainless Steel, Copper
Package Contents: Thermostat, Gasket
Thermostat Opening Temperature (°F): 195
Old Aug 23, 2014 | 05:39 PM
danr1's Avatar
danr1
Did you replace the thermostat?
You listed its part number its ratings and specs but didn't read where you stated that you had put a new one in.
Old Aug 23, 2014 | 10:44 PM
Krinderhagen
thank you
no i haven't replaced the thermostat i am doubting is the problem as it does not reach temp though will soon as i get a chance
Old Aug 24, 2014 | 07:03 AM
dixie460's Avatar
dixie460
A busted thermostat can cause your truck not to warm up. When I bought my current truck, it wouldn't warm up for crap. Took the t-stat housing off and the old thermostat came out in three pieces. Lol.
Old Aug 24, 2014 | 09:23 AM
tjc transport's Avatar
tjc transport
i ain't rite
engine stalling after releasing throttle has nothing to do with the engine temp. it is a sign of injector pump problems.
first thing to do is fire the engine up and get it warm.
then shut it off and remove the fuel filter. drain it, and fill with ATF.
put it back on and start the engine. let it idle for 30-45 seconds and shut off.
then let it sit for at least 12 hours, 24 hours is better.
the ATF will clean the crud off the inside of the injector pump.
if this does not fix the stalling problem, you will probably need a new injector pump.
Macs1964F100
Nov 9, 2013 06:54 PM
cutlass
51
Jun 16, 2011 12:54 PM
So-Cal Sancho
Jul 11, 2009 01:41 PM
Pubale
1997 - 2003 F150
Nov 4, 2007 10:23 PM
dhepler
1978 - 1996 Big Bronco
Feb 5, 2005 03:15 PM
