Modular V10 (6.8l)
What should be here?
Old 08-25-2014, 02:46 PM
Fifty4F100's Avatar
Fifty4F100
Fifty4F100 is offline
I am having some small problems with the 6.8 in my F53 MH chassis. It runs like a top, but has a little idle lope. To those who looked at my previous thread, its better. But while checking for vacuum leaks I found this:
I thought it would be something that moved. But what's there and bolted down is actually the rear of the intake manifold. What's supposed to be here?
Old 08-26-2014, 07:28 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Subscribing... no clue.
Old 08-26-2014, 09:28 AM
Bumble Guy's Avatar
Bumble Guy
Bumble Guy is offline
I have a 1999 class a motorhome same v 10 . Mine is same as second picture
Old 08-26-2014, 03:43 PM
northwindone's Avatar
northwindone
northwindone is offline
Looks like the one in this thread...
https://www.ford-trucks.com/forums/1...l#post14152934
I learned a little bit later on another thread that it was normal for some V10s as would be suggested by the response from Bumble Guy. I'm still curious why they would do it like this, but that seemed to be the answer.
Old 08-26-2014, 04:31 PM
Bumble Guy's Avatar
Bumble Guy
I know it doesn't look right with the metal hose and the gasket not lined up but it is the same on my v 10 so I wouldn't worry
Old 08-27-2014, 04:33 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
It's gotta be for EGR or vacuum something.
Where does the hose go?
And where does the other side go?
Old 08-28-2014, 08:28 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
this reminds me of my aircraft inspection days. mechanic's would do a great job on the bolts that they thought I could see and a crappy job on the bolts they thought I could not see.....but I used an inspection mirror and can see all the bolts.
so my take, this is a short cut on the assembly line and mechanics are putting in one bolt thinking the inspector cant see the other. later during service life of the vehicle...the two parts shift out of position and you have them hanging on out of alignment by one bolt.
the difficulty in trying to determine if it is a case vent is that multi cylinder engines equalize their case pressure as pistons move in and out resulting in no real sense of case vacume or pressure if you put your finger in the whole.
Old 08-31-2014, 08:08 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
weird... mine has it too. It is a passage to nowhere; i shined a flashlight up from the bottom and the light comes through the top.
Old 08-31-2014, 11:08 AM
khxor's Avatar
khxor
khxor is offline
That's a hole to nowhere. The Heads are interchangeable left to right, when installed on the left side that's at the front, coolant passage to the intake manifold for the t-stat. On the right it's there at the back, it's completely normal.
crazy96863
09-11-2013 06:48 PM
grandpa'sprideandjoy
West Virginia Chapter
18
10-12-2010 06:49 AM
glruff
Nebraska Chapter
366
05-29-2008 03:53 PM
phil6608
Georgia Chapter
388
05-01-2008 07:32 PM
phil6608
S. California Chapter
377
04-08-2008 04:27 PM
Quick Reply: What should be here?
