hi all.. I am trying to find the installation instruction for a 2013 ford expedition remote start al1z-19g364-a. I ordered it thinking its plug n play from talsa, but when it arrived it did'nt come with an installation guild. I called talsa and they said they don't have the installation instructions and that I have to go to the dealer to have it installed. any info anyone has would be appreciated thanks again..
Ok well i guess no one does have any info so i will try and attempt to install myself ill post some pics of the steps i took during install to help others so stay tuned
Yeah i saw that when i searched but its only a request to send an email of a PDF.. I dont see the PDF but thats what im trying to find.. So far i have it installed but the only problem im having is the exact location for the securelock interface. I know it goes around the ignition. But dont know if it matters the position of the interface. So im winging it.. Also i read that you have to have the shop activate the remote start i dont know how true that is..if so I'll make an appointment
So i finally was able to get the installation instructions. I cant believe it was that easy. It truely is plug n play for sync vehicles only all u have to do is program the remote after installation. U do need two other key fobs to program the remote for the start fob. And thats it.. It was so easy..
Ill post pics in a few days to show other that would like to do it themselves.
I thought you did still have to splice a few wires, no? I have a 14, and it came from the factory (technically dealer) installed, but I'm curious how much cutting went on to put it in there.
Thanks. Still thought you had had to splice a couple of wires. Anyway, what I've been trying to figure out is if there is anyway to use this key, with the remote start button, on these systems? if y ou put the remote start in programming mode, will it program to the fob's remote start button? The site I found it for sale on listed it for 2014 Expeditions with remote start. But they couldn't tell me why they listed it for 2014, when the remote start is the plug and play model, vs truly from factory. They just said it was listed as compatible for 2014's that came with this key already. I don't know of ANY 2014 Expy's that come with this key with any of the available remote starts. But if I could get it to work, I would LOVE to get rid of that separate RS fob.
I have a 2008 Navigator I want to install this on but I am in need of the installation instructions. Danny, would you suggest doing it yourself (I've installed many aftermarket radios over the years) or spend an extra $200 for labor to have the dealer install?
I am also looking for installation instructions for the remote start P/N AL1Z-19G364-A on my 2014 Expedition Limited (with Sync). Any help is much appreciated. Thanks!
I have pics and video I just installed on my 2010 last Sat., but for some reason my PC can't post to this forum and I have to use my wife's PC. If you want to PM me an address I can send them direct. Looks like you have the 200 series but the instructions are the same. There is a u tube video on the option 7 door mod and another video on mounting the antenna except it is for a pick up pass. side and the Exp. are installed on the drivers side but still good to see. You need all ignition keys, 3) sockets, 7/32 for the steering column cover 7 & 8mm for the knee bolster. There is a green receptacle above the emergency brake. Plug RMS harness into it and module. Mount antenna behind rearview mirror on clear glass only. As in video, tuck wire into headliner, over A pillar above airbag and down the rubber gasket between door and dash then plug into RMS module. Prime pats tumbler module and stick adhesive ring over ignition tumbler and plug into RMS module. While everything is accessible and on floor. Close door insert first key move to run when red security light goes out insert next key when light goes out remove key and hold remote start button until light goes solid, truck should start. Pats security module must be mounted further then 3" from any metal surface. RMS module tied nicely to wire harness above e brake. If you want the option 7 door mod do it when everything is on the floor.
Reason: add date
I made my first you tube channel David One and if you search for (Ford exp/ sync remote start) you should find one movie then use the channel to see the others.
