Deodorize A/C?
Old Aug 22, 2014 | 11:11 AM
Capt.Schenk's Avatar
Capt.Schenk
Deodorize A/C?
About 10 years ago I think I read something about spraying a deodorizer between the refrigerant line and it's insulation to help with a musty smell coming from the vents. Has anyone done this, and if so, what's recommended to use for a deodorizer? I think I may have read this in a Haynes manual.
Old Aug 22, 2014 | 11:30 AM
Bill Kay's Avatar
Bill Kay
If you take the blower out of the housing on the passenger side firewall under the hood you can see the evap. coil. It can be cleaned by spraying coil cleaner on it then rinsing it off with water. One bit of advice to keep this from reoccuring is to turn your A/C off and let your fan blow on high thru the vents for about 1 min prior to turning the truck off. This will help dry the coil off thus preventing mildew and the oder.
Old Aug 22, 2014 | 12:17 PM
helifixer's Avatar
helifixer
I have never found a "deodorizer" that last more than a day or 2 for this problem. If you are going try that just spray the deodorizer in the inlet by the floor with the system on max cold and low fan.
This right here is the best easy option, next option is to discharge system, remove evaporator and thoroughly clean the coils, with out getting any moisture in the system.
Old Aug 22, 2014 | 12:56 PM
Capt.Schenk
Thanks for the replies. I'll pull the fan and clean the coil.
Brian2003
Jan 7, 2022 12:48 PM
Bruker
General Automotive Discussion
Jun 6, 2008 10:36 PM
hickabilly
Jul 12, 2006 08:37 PM
terrys
Modular V8 (4.6L, 5.4L)
Mar 24, 2006 03:47 PM
dfisher1
Garage & Workshop
Feb 12, 2004 06:23 AM
