Speedo quit working
Old Jul 12, 2003 | 07:13 PM
grappledad's Avatar
grappledad
Speedo quit working
I tore out the rear end in my '89 F150 and the speedo quit working. I rebuilt it and the speedo still isn't working...anyone know what the problem could be? I cleaned off the magnet at the top of the rear end and it still isn't working. Any thoughts?
Old Jul 12, 2003 | 09:32 PM
MustangGT221's Avatar
MustangGT221
Speedo quit working
Well, by not woring, what do you mean? Can you describe the problem more. Does the mileage display? Does it work AT ALL?
Old Jul 12, 2003 | 10:39 PM
82F100SWB's Avatar
82F100SWB
Speedo quit working
An 89 has a mechanical speedometer, the VSS on the axle is only for the ABS system. Check the cable, it might have failed, or improperly engaged properly in the speedometer or gear in the transmission, or perhaps the gear itself may have failed.
Evan
Old Jul 12, 2003 | 11:28 PM
MustangGT221
Speedo quit working
Ahh yes, seems to me that I missed the 89'....it's usually the 92-96's that have problems.
Old Jul 13, 2003 | 05:54 AM
grappledad's Avatar
grappledad
Speedo quit working
thank you guys i will check for a cable today.and see whats up.
Old Jul 13, 2003 | 11:34 AM
BBBTruck's Avatar
BBBTruck
Speedo quit working
find the spec for the ohm reading across the sensor, check with an ohmmeter at the harness. If the meter replies over limit or nothing at all, there is an open somewhere in the circuit. If the ohmmeter replies 0 ohms, there is a dead short. If you obtain a decent reading, shake the cable to see if it is broken inside. If this checks out, move to the next harness point and repeat process.
Old Jul 13, 2003 | 05:38 PM
steve83's Avatar
steve83
Speedo quit working
BBB
It's not an electronic speedo.
dad
If the cable is worn, it has probably put so much stress on the plastic gears in the transmission tailhousing that one or both are stripped. That's what happened to mine, and it's why I converted to the electronic speedo (PSOM) that has already been referenced. It takes some effort, but I think it was well worth it. The gears are ~$8ea and the cable is ~$40.
Old Jul 22, 2003 | 01:13 PM
BBBTruck's Avatar
BBBTruck
Speedo quit working
youre right, got confused, oh well theres how to check your abs!
mots42
Jan 14, 2014 08:47 AM
Williamwebb292
Dec 31, 2013 01:46 AM
Kevin 1988
Jun 17, 2013 09:32 AM
ramrod7373
Dec 14, 2012 08:51 AM
Heatnbeat
Dec 10, 2006 10:08 AM
