Check Coolant Additive Question
Old Aug 23, 2014 | 03:04 PM
Dakster's Avatar
Dakster
The only concern I have about the degas bottle or dipping the radiator from the top is that the test kit, tests for contamination and if the fluid was contaminated with something heavier than the fluid it would at the bottom or on top of the petcock...
Old Aug 27, 2014 | 05:48 PM
Kpt3's Avatar
Kpt3
How do you reset the indicator?
Old Aug 27, 2014 | 06:44 PM
senix's Avatar
senix
If I recall go to the information screen and you should see the message there to hold and reset.
Old Aug 29, 2014 | 08:39 AM
JandC's Avatar
JandC
My first "test coolant" notification came on at 38,000 miles.
Old Aug 29, 2014 | 09:06 PM
Kpt3's Avatar
Kpt3
Tried that but the warning came back the next time I restarted the engine
Old Aug 29, 2014 | 10:54 PM
Painted Horse's Avatar
Painted Horse
In the command center screen, Go to the coolant and press the reset and hold it till it clears.
Another interesting tidbit. Is the instructions say to test when the coolant is ambiant temp. Not when it's hot. How many dealers have you pull in and pull the test with coolant that is probably 180-190°. Technically you should park the truck and let it cool off before testing.
The main test is for Nitrates, If you never put anything into your coolant system, this should always test negative. So it is mainly looking to see if somebody added the coolant.
The Rejuvinator can be added twice during the coolants 105,000 mile life expectancy. It may be cheaper to add a couple bottles of rejuvinator at 35,000 and 70,000 and skip the test strips if you know that nobody has added the wrong coolant to your truck.
Matthew Barnes
May 12, 2017 05:32 PM
montauk1
6.7L Power Stroke Diesel
Apr 27, 2017 07:14 AM
rtazz17
19
Sep 6, 2016 10:57 AM
teppler
Jan 29, 2010 06:37 PM
jake 98
Dec 2, 2004 06:56 AM
