Keys
Old Aug 21, 2014 | 06:53 AM
Shadowrider123's Avatar
Shadowrider123
Keys
My 64 F100 and 65 Mustang use the same ignition and door lock cylinders.
Is it possible to have them keyed the same?
PITA keeping up with a bunch of keys.
Old Aug 21, 2014 | 10:31 AM
sseebart's Avatar
sseebart
A good locksmith should be able to rework the cylinders. I had multiple keys for my 64 tbird (door and ignition were different--go figure!) and had the cylinders done for about $20 each, after I removed them myself.
~Steve
Old Aug 21, 2014 | 12:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The ignition and door lock keys are the same, but the cylinders are not the same.
1961/66 truck uses the same cylinders as 1961/64 Galaxie, 1965/66 Mustang uses the same cylinders as 1965 Fairlane/Falcon.
In order to have both vehicles keyed alike, you'll have to remove all the cylinders and have a locksmith replace the tumblers.
Old Aug 21, 2014 | 05:18 PM
jowilker's Avatar
jowilker
If the key form one will fit the other, (your first clue) a locksmith can repin one with the key from the other, to make one key work in both.
John
milkstake
Jun 14, 2017 07:04 AM
Tedster9
Jan 27, 2015 12:35 PM
tiny terror
Jul 5, 2009 05:42 AM
Michael Sizemore
May 5, 2004 06:46 AM
sbryant
Oct 3, 2002 07:36 AM
