Will this rub?
Old Aug 20, 2014 | 07:45 PM
NeilM67's Avatar
NeilM67
Will this rub?
I am considering buying a set of rims. They are 18"x10" with a -12mm offset. I am planning on putting 275/70/R16 tires on them.
My excursion has the V-code/modded B-code springs with stock front hanger and stock rear spacer.
Anyone else have a similar set up? Just trying to see/hear if this set up will rub.
-Neil
Old Aug 20, 2014 | 10:21 PM
X-Hibition's Avatar
X-Hibition
It won't rub because you can't put a sixteen inch tire on an eighteen inch rim.
Old Aug 20, 2014 | 10:45 PM
NeilM67's Avatar
NeilM67
Oops!
275/70/R18
Old Aug 21, 2014 | 06:24 PM
X-Hibition's Avatar
X-Hibition
Your tire size is one smaller than mine, forget I have a five inch lift, and with your modded springs you should be fine. What may be problematic is your offset.
Innocent Bystander
Jun 4, 2015 12:32 PM
martinpepek
Nov 18, 2010 08:46 PM
mxracer3276
Mar 3, 2010 07:27 PM
turban8r
Dec 13, 2007 09:38 AM
92f150I6
Jan 21, 2004 08:45 PM
