help vibram daper????
Old Jul 12, 2003 | 05:43 PM
jvicars4's Avatar
jvicars4
Ok, My 460 is stripped excep t as I try to remove the timing chain cover there is what I call a vibram daper in from that will not come off. I pulled the large bolt and got the pullys off but this (like an upside down triangle weight) does not seem to want to come off. Help.
Jamie
87 460
Old Jul 12, 2003 | 09:27 PM
Superdave's Avatar
Superdave
Just tap it lightly on the side with a small hammer while pulling on the counter weight with your other hand. You should be able to walk it off the crank like that.
And I emphasize "don't pound it", just tap.
Old Jul 12, 2003 | 09:52 PM
Dartagnan00001's Avatar
Dartagnan00001
Might squirt it with some wd 40 first, it's machined pretty close, a grain of sand will cause it to hang, but when clean slides like it was meant to....
Dart
Old Jul 14, 2003 | 01:28 AM
Superdave's Avatar
Superdave
When I tore my 79, 460 down, the counter weight was stuck on it too. I just lightly tapped it with a hammer while pulling on it and it came right loose and slid off the crank.
But yes, the WD-40 is a good idea too.
Old Jul 14, 2003 | 10:52 AM
airharley's Avatar
airharley
Is the woodruff key uneven? Sometimes that will cause the spacer to stick.
