transmission fluid
Old Aug 19, 2014 | 11:26 PM
jspence105's Avatar
jspence105
transmission fluid
Well folks I'm going through some transmission fluid. I just had to add a quart. I checked it 3500 miles ago and it was find. I've been towing my travel trailer all of that 3500 miles. I haven't noticed any leaks but I was low. I haven't noticed any other issues with it. How big of a concern is this? I still have 3000 miles to go on my trip
Old Aug 19, 2014 | 11:58 PM
The2003Excursion's Avatar
The2003Excursion
Sorry, but have to ask.
Were both done at the same temp?
Old Aug 20, 2014 | 12:43 AM
jspence105's Avatar
jspence105
The engine was warm both times I checked
Old Aug 20, 2014 | 01:34 AM
Stewart_H's Avatar
Stewart_H
Do you have a trans fluid temp gauge? If yes, check to make sure where you have the sensor screwed into the port on the side of the trans, isn't leaking fluid.
Stewart
Old Aug 20, 2014 | 06:06 AM
projectSHO89's Avatar
projectSHO89
It's the transmission that has to be up to temp, not the engine. If the transmission was not at the same temperature for all checks, the readings will be different.
Either it's leaking or it isn't. If it's not visible, check inside the radiator as it's possible to leak into there.
1L243
Aug 5, 2019 10:53 AM
fordman19762003
Jun 4, 2018 07:58 AM
fordman19762003
Jun 10, 2013 07:23 PM
priv8pilot
Nov 18, 2006 08:56 AM
Edkajo
Apr 14, 2004 07:25 PM
