Ignition problem
Old Aug 19, 2014 | 02:22 PM
fly-tying.guy's Avatar
fly-tying.guy
Ignition problem
So my truck will start but as it warms up it will die and not start again like a electric problem. I replaced the coil and ignition box and it still does it. It is also arcing across the coil. Would my distributor need rebuilt? Any other suggestions would be taken as well thank you.
Old Aug 19, 2014 | 02:54 PM
Franklin2's Avatar
Franklin2
Have you looked at the dist cap and the rotor underneath? The question you have to ask; Why would the spark rather jump across the top of the coil, rather than go into the dist cap, through the rotor, and down the plug wires to the sparkplugs? What shape are the sparkplugs in also?
Old Aug 19, 2014 | 03:11 PM
fly-tying.guy
I will look at the cap and roter the spark plugs are brand new less then ten miles on them
Old Aug 19, 2014 | 05:55 PM
KsCop's Avatar
KsCop
Ignition system is pretty simple. I'd start at the beginning and check each part;
Power to Coil (obvious if it's arcing)
Coil OK?
HT Lead? (lead from coil to dist. cap)
Cap OK, no cracks, etc
Rotator
Points
Condensor (if this is bad, spark when points open won't be reduced and all sorts of interesting things can happen)
Plug wires
Plugs (gap, cracks, etc)
Inch by Inch..
Old Aug 19, 2014 | 08:33 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
There's no condenser or points in a DSII system...
check the resistance of the distributor pickup when it dies.
Unplug the distributor and ohm out the orange and purple wires.
IIRC it should be between 450-1,000 ohms.
Feel the ignition coil.
Is it scorching hot when the truck is acting up?
Old Aug 20, 2014 | 11:29 AM
slashfan7964's Avatar
slashfan7964
That depends if he's running a DSII system at all. We don't know, but most likely.
Old Aug 20, 2014 | 12:19 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Why don't you check his post history Angelo?
I remember he is from Wyoming or something and had this truck in his school's shop back when he was trying to get it running.
Old Aug 20, 2014 | 12:23 PM
fly-tying.guy
I am running the standard ignition I will get back after I can check on the cap and rotor.
xjoedirt55x
Feb 13, 2008 04:39 PM
Ihorse
3.8 & 4.2L V6
Jan 27, 2006 04:53 PM
Orange '63
Aug 17, 2004 06:20 PM
Rat wagon
13
Jan 2, 2004 02:17 PM
Coondawg
Dec 7, 2003 02:37 PM
