Random Battery Death?
Old Aug 19, 2014 | 11:42 PM
The2003Excursion's Avatar
The2003Excursion
Testing
This is not going to fix anything, but it is awesome for testing your battery, alternator and starter. Napa wanted over $100 for it, so I got it at Amazon.
Again, doesn't fix things, but I can't imagine going without it now.
Old Aug 20, 2014 | 08:11 PM
RevLemmon's Avatar
RevLemmon
How can I disable the courtesy light so I can leave the driver side door open so I can check the fuses?
Old Aug 20, 2014 | 08:12 PM
RevLemmon's Avatar
RevLemmon
Originally Posted by william_04_x
The computer doesn't draw THAT much! Not even close. You shouldn't see much more than 300ma, if all lights are off, and the computers have gone to "sleep".
The alternator is a likely suspect. You can disconnect the batteries, and alt, then re-test to verify. I assume you have a DMM, and the leads are being placed in series with the battery cable? How hot is the alternator getting 10mins after a cold start, with no load?
The alternator gets warm I can put my fingers on it for a few seconds its not blazing hot.
Old Aug 20, 2014 | 08:29 PM
william_04_x's Avatar
william_04_x
At least its not cooking, yet. Have you disconnected the alt charging lead, and taken any measurements? Remember its connected to the positive terminal of the battery, so disconnect the battery and protect any exposed connections accordingly. If no change, it's fuse pulling time.
Old Aug 21, 2014 | 08:35 AM
RevLemmon's Avatar
RevLemmon
I did disconnect the alternator last night and checked the diodes, I got a reading of 428 on way and nothing the other way. I'm keeping the negative on the battery disconnected until I figure out what's going on.
Old Aug 21, 2014 | 11:00 AM
william_04_x
Did you do your ampacity load test between battery and cable with the alt disconnected?
Old Aug 21, 2014 | 11:51 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Subscribing, the 7.3 is having the same problem.
It's either a parasitic draw or one of the batteries is bad, I'll find out this evening.
Old Aug 21, 2014 | 01:05 PM
william_04_x
I had a buddy with an 03 6.0l, and the same problem. I went through this same procedure to identify the problem. It ended up being a bad battery. The bad battery was only two months old.
Old Aug 21, 2014 | 01:47 PM
Toreador_Diesel
Starting to think the same thing...
I topped the batteries off and they did what they were supposed to, but I think all I did was buy myself some time. Gonna run them by Autozone after work Friday.
Just didn't want to have to spend money on two new batteries
Old Aug 21, 2014 | 01:52 PM
Misky6.0's Avatar
Misky6.0
Disconnect one lead from battery A - while measuring the current draw from battery B. Read the voltage on battery B.
Re-connect battery A's cable.
Disconnect one lead from battery B - while measuring the current draw from battery A. Read the voltage on battery A.
Re-connect battery B's cable.
IF one battery is pulling the other down because it has a bad cell (or two) - this should determine which battery it is..
Old Aug 21, 2014 | 06:14 PM
william_04_x
It's worth having them tested to make sure. Make sure both negatives, and positives are removed so the batteries are truly tested independently. Parts store guys won't always do that. Check to make sure the parrallel positive cable between the batteries is in good condition. It runs right across the front/top of the radiator in the cooling stack. Easy to inspect.
The OP has had his battery tested, and it checked okay. If it is, something is pulling it down. All the troubleshooting can be done in an hour if you move through it efficiently.
Old Aug 21, 2014 | 06:16 PM
RevLemmon's Avatar
RevLemmon
Ya I had the alternator disconnected completely. A friend of mine was sure that it was the source of the draw that he helped me take out of the truck. Retested and still got the same 8 amp draw that dropped down to about 6 amps after a few minutes.
Old Aug 21, 2014 | 06:35 PM
  #28
william_04_x
Originally Posted by RevLemmon
Ya I had the alternator disconnected completely. A friend of mine was sure that it was the source of the draw that he helped me take out of the truck. Retested and still got the same 8 amp draw that dropped down to about 6y amps after a few minutes.
Now its time to pull fuses, and relays. Having a buddy with you here really speeds things up. One guy watching the meter, and the other pulling and replacing until you see a dramatic change. It helps to identify the constant sources first(PCM/radio memory/etc) first. Get them out of the way, and note how much of a load they contribute. Hopefully in the 20A setting on your meter, you still have resolution down to at least hundreths (x.xxA).When the offending circuit is identified, leave its fuse out, bring the constants back up first, and verify the load is similar to what was noted when they were pulled. The PCM can draw a higher initial load when first energized(as it's basically rebooting), and will stabilize to a lower reading after it sleeps(can be several minutes).
Old Aug 21, 2014 | 06:43 PM
  #29
BruteFord's Avatar
BruteFord
Yes I have a digital, cheap one from harbor freight so I know its not the most accurate thing in the world but its not that bad either.
Is it the one with the red plastic housing? If so, I have IDK 8 or 10 of those, HF gave them away for a while, they SUCK. I bet if I was too hook up all the ones I have to the same battery at the same time I'd get 8 different readings. I am a HF fan but have HORRIBLE history with all of the CEN-TECH products, I don't even take the free ones anymore. My point, you can not rely on it for this.
http://www.harborfreight.com/7-funct...ter-92020.html
My suggestion pickup a cheap buzzer and a couple alligator clips. Clip it in place on the battery post and cable clamp. This way you don't have to be anywhere near it, not even see it. Then pull/unplug things until the buzzing stops.
Amazon.com: DC 3-24V 30mA Industrial Continuous Sound Electronic Buzzer 80dB: Automotive Amazon.com: DC 3-24V 30mA Industrial Continuous Sound Electronic Buzzer 80dB: Automotive
Amazon.com: Cal Term 70308 Charging Clips 16-14 Awg: Power & Hand Tools Amazon.com: Cal Term 70308 Charging Clips 16-14 Awg: Power & Hand Tools
Old Aug 21, 2014 | 06:53 PM
  #30
william_04_x
Originally Posted by BruteFord
Is it the one with the red plastic housing? If so, I have IDK 8 or 10 of those HF gave them away for a while, they SUCK. I bet if I was too hook up all the ones I have to the same battery at the same time I'd get 8 different readings. I am a HF fan but have HORRIBLE history with all of the CEN-TECH products, I don't even take the free ones anymore. My point, you can not rely on it for this.
I haven't used the HF tester, but I personally don't like anything except a good DMM if series load testing sensitive electronics. The only reason is that the resistive value of a DMM is very low, which keeps the voltage at the upstream devices closer to battery voltage. Series resistors are voltage dividers. Anything placed in series of the tested circuit will have an affect on the voltage available to the other loads in the circuit. Test lights, and buzzers aren't huge resistors, but more than I'm comfortable with when placed in series with a PCM, or expensive radio head unit. My $.02, YMMV, TIFWIW.
