chime noise
Old Aug 18, 2014 | 09:08 PM
spyder0382's Avatar
spyder0382
chime noise
Ok I replace an ignition module and have always had a bad clockspring bit after I replace module the 5 chimes every 30 or so minutes staryed to happen and now it won't stop chiming it does it continuously door open or closed. Key in or out just wondering if replacing clockspring will solve it or is it a bad module
Old Aug 19, 2014 | 04:24 PM
tjc transport's Avatar
tjc transport
i ain't rite
5 chimes usually is an indicator of air bag problem.
so if you have a bad clock spring, it is very possible the airbag wires broke giving you the 5 chime warning.
Old Aug 19, 2014 | 06:49 PM
dixie460's Avatar
dixie460
The 5 chimes (repeated in groups of 5) simply means your airbag idiot light is inoperative. Probably just the bulb finally burnt out.
The airbag diagnostic module chimes to get your attention, because with the bulb blown, it has no other way of warning you. Note that even if there are no faults stored in the module, a blown bulb will still cause it to chime.
Old Aug 19, 2014 | 09:05 PM
spyder0382's Avatar
spyder0382
I replaced all bulbs just in case of that but now the chime doesn't stop until the truck is running
Old Dec 17, 2014 | 08:02 AM
spyder0382's Avatar
spyder0382
Found code for clock spring originally (no horn) replace the clock spring horn now works but after replacing I smelt a burning smell found the fuse inside air bag module burnt out
Old Dec 17, 2014 | 11:30 AM
dixie460's Avatar
dixie460
That fuse is a thermal fuse, not a current limiting fuse. They're normally used to prevent an overheat condition in things like coffee makers and such, but the airbag module uses it as a self-destruct feature.
When you opened up the module you found that fuse inside a little plastic housing on the board, right? Did you also notice the resistor in there next to it? What happens is when the module detects certain faults, it sends current to that resistor next to the thermal fuse and the resistor heats up and blows the fuse. What this actually accomplishes I can't say for SURE, but I'm fairly certain it disables the airbag firing circuit... I'd have to see a schematic to be sure though.
Ford says this is not a repairable part and to replace the entire module when that fuse blows. I say otherwise... if you know the value of that fuse you could certainly replace it after you fix the problem that caused it to blow in the first place.
Old Dec 17, 2014 | 11:32 AM
spyder0382's Avatar
spyder0382
or just let it be since the first Gen air bags are so lethal
Old Dec 17, 2014 | 11:33 AM
dixie460's Avatar
dixie460
Look what I found with a quick Google search!
HOW TO GUIDE: Airbag Code #51 Fix w/ pics - ProbeTalk.com Forums
Old Dec 17, 2014 | 11:40 AM
dixie460's Avatar
dixie460
Lol. I took mine out because of some modifications I made to my frame with the winch mount, and decided to have some fun with it like I always do with old airbags. I wanted the trim piece so my steering wheel looked stock, but I took the explosive charge off the back, buried it in the yard, moved the truck and everyone else a good distance away, and since my battery charger refuses to put out any juice unless it sees an actual battery connected, I wired the squib to an extension cord and plugged it in the wall... and TWO whole seconds later the damn thing finally fired. Lot of good that would have done in a wreck...
Maybe it's just cause I used ten times the normal voltage to fire it (120V instead of 12V) but I don't see why it would have mattered.
Old Dec 17, 2014 | 11:41 AM
spyder0382's Avatar
spyder0382
Nice write up doesn't look to bad of a job. Do you know where air bag sensors are on a 94 f150 , or how to check for multiple codes originally I only had the code for the clock spring then the fuse blew and threw the code for the fuse? Thanks for the input
Old Dec 17, 2014 | 11:44 AM
dixie460's Avatar
dixie460
Primary crash sensors are up front on the core support, one on each side. The safing sensor on mine (Supercab) is just aft of the door opening, can't remember but I think it was the passenger side. Not sure where it is on other cabs. And the codes will flash out on the airbag light one after the other.
Old Dec 17, 2014 | 02:59 PM
daddylee100's Avatar
daddylee100
Airbag warning light is out. Chime is secondary warning.
Old Dec 17, 2014 | 03:11 PM
spyder0382's Avatar
spyder0382
All bulbs in dash are working and replaced already
Old Dec 17, 2014 | 04:07 PM
FordxFour's Avatar
FordxFour
Have you tried disconnecting/reconnecting the battery after changing the bulbs?
Old Dec 17, 2014 | 05:03 PM
spyder0382's Avatar
spyder0382
Fuse inside module is fried
Glide1995
May 29, 2018 12:03 PM
BigVanVader
1997 - 2003 F150
Mar 9, 2011 06:08 PM
beeshoo
Apr 15, 2007 01:52 PM
patrick_q
1983 - 2012 Ranger & B-Series
20
Feb 17, 2004 09:18 PM
bgbytor
Jul 9, 2002 06:31 AM
