Long time reader, first time poster. These forums have been a great resource for me, but I've run into the first question that a search didn't uncover a solid answer to.
I have a 99 2wd F350, and a 2001 4wd Excursion. Is the Excursion a viable donor vehicle for a 4wd conversion on the F350, or will I run into issues where necessary parts simply are not interchangeable? They're both V10s, so I'm not concerned with any differences between gas/diesel (if there were any even).
I fully realize that even if it works it would be a significant time investment, but the Excursion is coming apart either way since its body is trashed but its mechanics are sound, so it would be hugely convenient if I could use its parts for this.
I do believe everything will bolt right in the only thing that might be different are the drive shaft lengths..
Thanks for the quick responses guys. I suspect the drive shaft will indeed be something I'd need as the F350 is a long bed CC.
The F350 is a manual too, so that's another aspect that differs between them. As far as engaging the 4wd, I was hoping to use the Ex's electronic diff.
