ICP IRP
Old Aug 18, 2014 | 12:57 AM
fishdaddymoe's Avatar
fishdaddymoe
ICP IRP
I have a 2003 F 250 with a 6.0 diesel which has been fully "Bullet Proofed" I have an oil leak that occurs when the truck is parked level or facing up hill on the driver's side. (on the exhaust) I was told it is usually the ICP or IRP both have been replaced but I still have the leak and I am unable to see where its coming from. Any suggestions?
Old Aug 18, 2014 | 01:16 AM
Yahiko's Avatar
Yahiko
It's IPR
Injection Pressure Regulator.
Yes that could be the problem and will only get worse
when it starts to erode the wires on that plug.
You should dig into it to make sure that is the leak
and if it is then replace the regulator and the harness
plug end.
Come on over to 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Also we will see if one of the Mods will move this to the right place.
Sean
Old Aug 18, 2014 | 01:19 AM
fishdaddymoe
ICP IPR
Both have been replaced leak is NOT coming from either. Any other suggestions
Old Aug 18, 2014 | 08:34 AM
9228.bobcat's Avatar
9228.bobcat
Could be valve cover bolt or glow plug harness. I have seen a lot of 6.0 that people have worked on that have left that back bolt out because it's in a tight spot.
Old Aug 30, 2014 | 08:18 PM
fishdaddymoe
Thanks for the responces guys. It was the upper valve cover gasket.
xcellent
Jul 1, 2015 09:44 PM
rhodester
Apr 7, 2014 10:46 AM
mexicoF250
Nov 20, 2009 10:27 AM
Groundpounder0331
Dec 27, 2004 02:22 PM
RedRage
Nov 3, 2004 11:26 AM
