cab swap questions
Old Aug 17, 2014 | 04:02 PM
mechmike360's Avatar
mechmike360
cab swap questions
I have a rusted out right side of my cab. its a 74 f100 390 4spd 4x4 no a/c.
The doner truck is a 76 f150 460 auto 2wd w a/c.
Wondering if the the auto 2wd cab will be easy to change: petals, floor board for shifters, would the ac from the 460 bolt to the 390? Or would i be stuck with the a/c box for nothing.
Old Aug 17, 2014 | 04:24 PM
GM4WALLS's Avatar
GM4WALLS
I cannot answer about the AC, but the cab swap is pretty easy. I just unhooked the peddles, removed the master cylinder and emergency brake. Had to remove the steering column and the shift linkage. I unplugged all the wiring outside the cab and removed the four bolts holding it on. Prior to this I removed the front clip. The entire ordeal took me 3 hours for one cab.
Old Aug 17, 2014 | 05:06 PM
lafermedavid's Avatar
lafermedavid
cab removal working by yourself
Old Aug 17, 2014 | 05:12 PM
lafermedavid
try to get pics of existing cab,see how bad as well as your doner.not sure on ac probably just a bracket.Mike Oh has a/c on 390 plenty of help here
BigMightySam5600
Oct 6, 2012 07:07 PM
rangergirl94
37
Apr 12, 2012 04:35 PM
Weezman
Apr 1, 2011 10:18 AM
jb10
Feb 21, 2010 10:03 PM
