brakes
Old Aug 14, 2014 | 10:30 PM
mrf-100's Avatar
mrf-100
brakes
hello all ive been building a 56 , and cant get the brakes to bleed tried a few different ways , still nothing no leaks that I can see , its a under floor vacuum booster with a late model master and a wildwood proportioning valve set up volare disc front , drum rear , with a 10 pound residual vale at the rear and a 2 lb one in front , when I start the truck the pedal goes all the way down /I have better brakes after bleeding before starting it ? booster bad ?, any tips would be greatly appreciated
Old Aug 15, 2014 | 08:06 AM
teardropty's Avatar
teardropty
I would check the master cylinder. I had a new corvette style master that leaked past the seals and caused all kinds of headaches. Once that checks out, check all your connections for leaks. Sometimes you have to power bleed the brakes with a machine.
Old Aug 19, 2014 | 08:18 PM
mrf-100's Avatar
mrf-100
turns out it was the front calipers I had them switched from side to side , whouda thought ? not me
1930 Dodge
35
Jan 13, 2013 07:18 AM
Zimm3
Aug 6, 2009 09:16 PM
bigben4x
Mar 7, 2007 09:30 AM
mxer201
Aug 20, 2002 09:35 PM
