water pump
Old Jul 12, 2003 | 05:58 AM
stuperscout's Avatar
stuperscout
Question water pump
Does anyone know if a late 80s early 90s water pump will fit on a 70s vintage front cover/engine and is rotation the same way?
Old Jul 12, 2003 | 08:20 AM
georgedavila's Avatar
georgedavila
water pump
I have an Edelbrock Water Pump and it's listed as fitting '70-92 460s. I don't know if the serpentine belts use reverse rotation, or if that's an issue on the pump.
Old Jul 12, 2003 | 07:27 PM
stuperscout
water pump
I didn't know if the pump would fit after I posted I dug up a set of serp. pullys I had bought for this project and they indicate standard rotation, Ribbed not smooth like reverse rotation So I'm thinking if the pump fits ok rotation should not pose a problem even if I have to shim pulleys accordingly
Thanks chris
