Ok so you guessed it I'm trying to reset the adaptive learning tables what scanner will allow me to do this. I have been looking into doing this but nobody ever posts about it all I ever come up with is the tsb's saying to do it but never a scanner to perform the task. Auto enginuity seems to be the most in depth and runs on a lap top I'm guessing it can but that would be a 450 dollar mistake if it can't.
As far as I know I've never seen aftermarket scanners capable of resetting adaptive tables only 3 you can reset hpp and fuel injectors and egr tables and dpf tables can I ask why you wanna reset tables and only way I know is using ids Ford scanner
Replacing injection pump along with booster pump. The red and black one on amazon for 208 dollars?
Thank you
Autoenginuity will reset the DPF tables. I think the EGR and tranny tables are cleared whenever the battery is pulled. I seem to remember paying $360
for the AE + Ford enhanced package.
Thank you I'll try the battery method first then look at scanners. What do you think of Autoenginuity? What have you done with it?
Brian
AE is great. It is almost as good as the dealer tool in terms of PID coverage.
I used it to plot the movement of my blend doors moving around and intermittent ticking to convince the dealer to get it fixed.
I also used it to plot my DPF and CAT temperatures while in regen. I think I have a few pics in my gallery. There's a mode to allow programming a spare key with only 1 master key. That pays for itself compared to a dealer trip!
