Radius arm
Old Apr 15, 2018 | 10:15 AM
Keith Wells's Avatar
Keith Wells
Radius arm
Looking to find radius arms for my 1978 F-250 2wd.... Can find all other parts related to them just not the arm itself.. it is all stock. The part the bushings go on are worn badly... Previous own didn't take good care of it.... Any ideas where to get a set? New would be great, good used one would be nice too... Does anyone know interchangeable ones that would work? Can't seem to find much info.... Thanks...
Old Apr 15, 2018 | 10:37 AM
JessyJ's Avatar
JessyJ
Time to get the welder out. Run multipul beads, then do some grinding.
Old Apr 15, 2018 | 10:43 AM
David7.3's Avatar
David7.3
I agree with Jesse, have done it many times my self, unless you can find any still on the truck in the bone yard but I bet someone beat ya too it. Did you check Cheesebay? You never know.
Old Apr 15, 2018 | 10:51 AM
speedfreak78's Avatar
speedfreak78
Check Craigslist, car-part.com or Google "1978 F-250 2wd radius arms" there's a bunch of options that show up.
Old Apr 15, 2018 | 02:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Keith Wells
Looking to find radius arms for my 1978 F250 2WD.... Can find all other parts related to them just not the arm itself.. it is all stock. The part the bushings go on are worn badly.
D5TZ-3A360-A .. Radius Arm - R/L same / Obsolete
1975/79 F100/150 2WD; 1975/79 F250 2WD Regular & Crew Cabs; 1975/79 F250 2WD Super Cab except with 8,100 lbs. GVWR (Gross Vehicle Weight Rating).
No Ford dealer or obsolete parts vendor has any.
1975/79: F250 Super Cabs with 8,100 lbs. GVWR & F350 2WD are different!
Old Apr 15, 2018 | 08:11 PM
black & blue 78/9's Avatar
black & blue 78/9
Hey Number Dummy
Hey ND, Would the radius arms from a 79 E150 fit? My local jy has some good RA that have new rear bushings.
Old Apr 15, 2018 | 08:27 PM
NumberDummy
No.
E100/150 & E250/350 are different.
Old Apr 16, 2018 | 06:26 AM
TTurnquist's Avatar
TTurnquist
I took mine to a local machine shop and had them replace the pins, cost $80.
Old Apr 16, 2018 | 08:28 AM
Ug666's Avatar
Ug666
Seeing 3x 75-79 trucks online in my local JYs, the JYs without a web site quite often have the older stuff still.
Old Apr 19, 2018 | 06:48 AM
benbuilder's Avatar
benbuilder
I have a set of an f350, I am not sure if they match.
Old Apr 19, 2018 | 02:50 PM
NumberDummy
Originally Posted by benbuilder
I have a set of an F350, I am not sure if they match.
Not the same, see post #5.
Old Apr 19, 2018 | 03:30 PM
benbuilder's Avatar
benbuilder
SORRY, I STOPPED READING AFTER YOU SAID
"No Ford dealer or obsolete parts vendor has any."
Old Apr 19, 2018 | 03:43 PM
NumberDummy
I said this in the 3rd line. Do you see F350 mentioned in the 2nd line where I listed the applications?
Old May 20, 2018 | 05:32 AM
applebaggins's Avatar
applebaggins
How difficult would this be for a novice welder? I just snapped the threaded end off my radius arm and need to replace it or fix it. Am I better off taking it to a fabrication shop?
Gregs82F100
Aug 23, 2018 03:11 AM
PIDI
North Carolina Chapter
Apr 17, 2012 07:36 AM
79F150FT
13
Jul 10, 2005 09:29 PM
tediesel
Aug 7, 2004 12:25 PM
