Fomoco rtv
Old Aug 13, 2014 | 07:04 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Fomoco rtv
Someone on here must have a trick to get the engine rtv off these motors. Please enlighten me
Old Aug 13, 2014 | 07:06 PM
ReBilld's Avatar
ReBilld
I scrape what I can off, then use a wire brush in a die grinder to get the rest.
Old Aug 13, 2014 | 07:08 PM
MOOSE_MACHINE
That bad eh
Old Aug 13, 2014 | 07:46 PM
fordpride's Avatar
fordpride
Scrape what you can and use a scotch brite on a drill, dremel of die grinder
Old Aug 13, 2014 | 08:13 PM
427 fordman's Avatar
427 fordman
Air chisel.
Old Aug 13, 2014 | 08:15 PM
Diesel_Brad's Avatar
Diesel_Brad
Razor blade and carb cleaner on a rag.
Be very careful with a scotch brite pad. The crumbs wipe out bearings
Old Aug 14, 2014 | 11:03 AM
MOOSE_MACHINE
Well I used a razor blade for the big stuff then dropped it in the solvent tank and finally scrubbed with a scotchbrite. Worked well
Old Aug 14, 2014 | 12:49 PM
DIYMechanic's Avatar
DIYMechanic
On something as hard as the cast iron engine block on these engines I wouldn't hesitate to lay into it with a grinder and cup brush if you can get it into where you need to be.
Old Aug 14, 2014 | 01:42 PM
MOOSE_MACHINE
The block was the easy part. Hot tank and done
Old Aug 14, 2014 | 07:01 PM
DIYMechanic
I've used the cup brush on the tins as well, just use a softer brush, not one of the ones with the twisted bristles. I generally lay them upside down on the bench and run a screw through a couple of the holes to hold them still so they aren't skittering about as I am cleaning them. A variable speed grinder makes that a lot easier too.
Dr G
Aug 23, 2016 08:41 PM
f150_514ci
Garage & Workshop
15
Nov 17, 2005 03:33 PM
wyldstallyn73
Garage & Workshop
Nov 24, 2004 04:14 AM
stumpy2
Garage & Workshop
Jan 30, 2004 06:41 AM
Torque1st
Garage & Workshop
Dec 30, 2002 11:21 PM
